2.2 ?'s
Old Apr 13, 2008 | 09:23 PM
xplayer325's Avatar
2.2 ?'s
OK I have a 2006 cobalt Lt automatic I have a AEM cold air intake and complete 3.5 inch apexi exhaust I was wonderin what other mods I can do that won't cost me an arm and a leg. Is there actually a tune for the automatic and what is this shift kit I keep hearing people talk about.
Old Apr 13, 2008 | 09:28 PM
c0baltic's Avatar
You can lower the car, strust bat and sway bar, a shift kit.. B&M or Autotrans Interceptor(harder to find since they dont make em anymore)
a shift kit increases line preasure in your tranny and helps you shift quicker.. it dosnt make it any faster just gets rid of the lagg between gears.. also makes you chirp into 2nd lol
also .. you can go w/ a lil throttle in a bottle lol
Old Apr 13, 2008 | 09:29 PM
xplayer325's Avatar
ok if I was going about getting one of these shift kits where would i get one. and thanks for the quick reply
Old Apr 13, 2008 | 09:30 PM
umrdyldo's Avatar
Is your exhaust 3.5 inch or just the tip? 3.5 inches is way too big for the pipe sizing.
The tune will be coming for automatics soon from ClearImage, check the group buy section of clear image.
Once you get all of the intake and exhaust parts done you can start on suspension or looks.
The strut bar is a nice start. Sway bar group buy is also going on through Turbo Tech Racing.
Old Apr 13, 2008 | 09:31 PM
c0baltic's Avatar
http://www.youtube.com/watch?v=aOQh5Z07YS0
thats my car with a shift kit.. listen to the chirp
you can check out ebay or on here search the forums for B&M Shift Plus.. i have an Auto Trans Interceptor.. easier install just plugs in but they no longer make them but check ebay for that too
Old Apr 13, 2008 | 09:32 PM
MasterMike's Avatar
2.4 intake manifold upgrade kit from Crate engine Depot....ZZP header...
For the 2.2, an 2.25 inches exhaust like the GMPP is good enough...
Last edited by MasterMike; Apr 13, 2008 at 09:32 PM. Reason: Automerged Doublepost
xplayer325's Avatar
my exhaust is 3 inch sorry it is 3 inch all the way until the apexi muffler and then comes out at 4.5 inches on the tip
Old Apr 13, 2008 | 09:34 PM
umrdyldo's Avatar
You are losing a lot of torque down low with an exhaust that big. But the top end would be great.
Hell finish it off with the ZZP header and downpipe combo. 3 inch all the way. Loud as hell and power to spare.
INDColtsFan18's Avatar
get a smaller exhaust..lol
a header/dp combo....but your pretty much done with cheap performance mods.
xplayer325's Avatar
hey cobaltic what kind of exhaust do you have it sounds nice
Old Apr 13, 2008 | 09:36 PM
avenger09123's Avatar
Your going to have horsepower up the wazzu but your torque will be lacking with an exhaust that size....until your cranking enough out to warrant an exhaust that size....like they said Crate Engine Depot's 2.4L Intake Swap, body modifications for suspension. Maybe a grounding kit for your speaker clarity,
Old Apr 13, 2008 | 09:41 PM
xplayer325's Avatar
How hard is it to install the shift kit cause I found one for $18 dollars on ebay it's a B&M.
Old Apr 13, 2008 | 09:45 PM
umrdyldo's Avatar
yep that's the one.
There is a How TO on it in the "How-TO section"
take 5 or 10 minutes. Worth it.
Old Apr 13, 2008 | 09:47 PM
xplayer325's Avatar
http://cgi.ebay.com/ebaymotors/B-M-S...spagenameZWD1V
will this work on the 06 cobalt
Old Apr 13, 2008 | 10:00 PM
umrdyldo's Avatar
No you need this.
http://www.turbotechracing.com/produ...idproduct=4985
Old Apr 13, 2008 | 10:59 PM
xplayer325's Avatar
alright thanks
Old Apr 13, 2008 | 11:34 PM
c0baltic's Avatar
lol i am running stock right now your hearing my CAI.. it's loud as hell.. sounds nasty tho
Old Apr 13, 2008 | 11:58 PM
xplayer325's Avatar
What is a CAI
Old Apr 14, 2008 | 12:02 AM
justindar's Avatar
Why is it bad to have a big exhaust, what makes it lose the HP?
And CAI stands for Cold Air Intake it runs under the engine to get the outside air so its cooler air running to the engine.
Old Apr 14, 2008 | 12:13 AM
xplayer325's Avatar
sorry I am so stupid I just realized that it is cold air intake
Old Apr 14, 2008 | 12:18 AM
Jn2's Avatar
Jn2
get rid of the 3" exhaust, sell that to a f/i balt...and get a 2.25" exhaust, its all your caer needs, maybe 2.5 if you get a bit more mods, but def not 3"
Old Apr 14, 2008 | 02:38 PM
c0baltic's Avatar
because too big of an ecxhaust causes you to loose back pressuer on the engin wich causes HP loss..
Old Apr 14, 2008 | 02:46 PM
umrdyldo's Avatar
Go blow air through a 3 foot stormwater pipe and have somebody feel the pressure at the other end.
now blow through a straw.
Old Apr 14, 2008 | 03:17 PM
RedBaseBolt's Avatar
I have a header to 3 inch down pipe which tapers to 2.5 inches all the way back and it's the best combo I've found so far.
Old Apr 14, 2008 | 03:23 PM
o3nisoaso3's Avatar
cams and tune that bitch
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/2-2-beta-test-96709/
