2.2 s/c bolt on
Old Feb 24, 2015 | 01:19 AM
no_ss's Avatar
2.2 s/c bolt on
Okay, so I'm supposed to be looking at a s/c kit on a ion redline to buy the s/c kit off of and it has a 3.1" pulley. Will #34 injectors work? Or will o need the #42 injectors. I also have a throttle body cable and the harness for the injectors for when I do the swap so if there are any other adapters please let me know.
Old Feb 24, 2015 | 01:48 AM
andrewcarr1993's Avatar
You need #42's and the wire swap for the throttle body?
Old Feb 24, 2015 | 02:15 AM
Jesse's Avatar
42s, because with a 2.2 the 34# injectors will be maxed out on a stock pulley. And remember you will need these harnesses:
Throttle body harness(you are already getting)
LSJ MAP pigtail so you can wire the TMAP into your existing harness
MAF extension harness
Old Feb 24, 2015 | 06:22 AM
no_ss's Avatar
Originally Posted by supernovanator
42s, because with a 2.2 the 34# injectors will be maxed out on a stock pulley. And remember you will need these harnesses: Throttle body harness(you are already getting) LSJ MAP pigtail so you can wire the TMAP into your existing harness MAF extension harness
thanks for listing the other things I'll need this is actually really helpful. Since I'm getting #34 injectors and harness should I buy a new pulley for the supercharger when I get it? I did some digging on zzp and found all their suggestions about injectors and it says the smallest it can go on #34 is 3.25"
Old Feb 24, 2015 | 09:47 AM
sandman's Avatar
I'd still recommend buying a set of 42's incase you decide to go bigger and so then you dont have to put a stock pulley back on. I'm sure many others would agree with you on that.
TB harness good and that will save you some money
Using the lsj map isn't absolutely necessary but you can if you want. just more cash and more wiring
Maf extension harness isn't necessary either. You can just de-loom those wires and pull them apart and re loom them and it will be long enough saving you some money there too
Old Feb 24, 2015 | 07:18 PM
no_ss's Avatar
Originally Posted by sandman
I'd still recommend buying a set of 42's incase you decide to go bigger and so then you dont have to put a stock pulley back on. I'm sure many others would agree with you on that. TB harness good and that will save you some money Using the lsj map isn't absolutely necessary but you can if you want. just more cash and more wiring Maf extension harness isn't necessary either. You can just de-loom those wires and pull them apart and re loom them and it will be long enough saving you some money there too
I'm keeping stock internals for the time being, would a 3.1" pulley create too much boost for my engine? I'll have to definitely get a set of 42# injectors.
Old Feb 24, 2015 | 08:09 PM
sandman's Avatar
mine blew on a 3.1 most people can run down to a 2.8 without problems
Old Feb 24, 2015 | 08:50 PM
Jesse's Avatar
It depends horribly much on the tune. You can blow up the motor on a stock pulley really quickly with a bad tune.
Old Feb 25, 2015 | 01:27 AM
no_ss's Avatar
Okay thanks for clearing that up, didn't wanna blow the motor on my only car lol. I'll have to talk to Phil at Tampa tuning to see what he can do.
Old Feb 25, 2015 | 01:32 AM
James tuned his so that's all I can say. Yet the idiots on facebook still praise him.
Old Feb 25, 2015 | 01:34 AM
no_ss's Avatar
idk what you're talking about because I don't have Facebook
Old Feb 25, 2015 | 01:35 AM
no_ss's Avatar
Are you saying not to go to Phil? I want a dyno tune. I'm ready to spend 500$ on it when I get all the parts on. Just need somewhere in south west fl that will do a good job.
Old Feb 25, 2015 | 01:44 AM
Jesse's Avatar
Tampa Tuning conducted themselves very poorly on this site recently. IDK I think that's a strike against a business.
Old Feb 25, 2015 | 01:50 AM
no_ss's Avatar
I've heard good things about the tuning though. Idk that's what you guys are here for to look out for each other so none of us get screwed. If anyone knows a way to get a good tune let me know. My last resort would be sending my pcm to zzp and having my car sit for a week or so waiting on a flash tune but I need my car for work and school and id much rather hit a dyno.
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
CobaltSS 16
Sep 29, 2015 01:53 PM
