2.2 turbo questions
Old Dec 28, 2008 | 02:59 PM
Xiled Cobalt's Avatar
sounds good
Old Dec 28, 2008 | 03:02 PM
xCobalt05x's Avatar
oil pump works like a champ for me but i also have a rear mounted turbo so i have to do things different.
Old Dec 28, 2008 | 03:15 PM
Sentry's Avatar
I always wondered how that worked...
Old Dec 28, 2008 | 03:18 PM
Preston's Avatar
me too
Old Dec 28, 2008 | 03:22 PM
xCobalt05x's Avatar
if you have an engine mounted turbo then tapping the oil pan is fine. you need to have a way for the oil to drain naturally or assisted back to the crank case.
since my turbo is mounted at the rear and low it needs the pump to draw the oil from the turbo and back to the crank case. If you look between the tire and the turbo you will see a white object w/ lines going into it from the turbo... thats the oil pump
I have a dyno clicky in my sig
Old Dec 28, 2008 | 03:35 PM
Sentry's Avatar
If I were you I'd lower that thing to the ground, I wouldn't want anyone to know I had a rear mount.
Setup looks cool though!
Old Dec 28, 2008 | 03:44 PM
thats a clean set up
Can some of you other 2.2 cobalts post pics of your turbo set up.
Last edited by Xiled Cobalt; Dec 28, 2008 at 03:44 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 03:50 PM
Sentry's Avatar
Afraid that won't happen til next month, been a delay on the shipment of the rest of my parts.
Old Dec 28, 2008 | 04:09 PM
Preston's Avatar
can hoefully by the end of the week...waiting to receive
piping, bov, boost gauge, and exhaust flange.
and i'll be posting pics upon pics in my thread
Old Dec 28, 2008 | 04:44 PM
true. cant wait
Old Dec 28, 2008 | 05:03 PM
  #36
mrsilent13's Avatar
ill post pics up tomorrow..im currently at work...and i cant get on my photobucket...its a government computer...but ill show you mine and where i taped the bottom portion of the block for the oil return line...its the same place as the garrett kit...if you look at their website and the kit for our cobalt you will see what im talking about
btw my cobalt is also an automatic...and im working on pushing at least 300whp...which i dont think should be a problem after i upgrade my intake manifold...im planning on pushing somewhere around 16lbs...and then once i get a meth kit...ill push for more timing and boost...mayb 20lbs
Old Dec 28, 2008 | 05:10 PM
  #37
mkulrey13's Avatar
You can run the garrett kit on your automatic cobalt..Reason they say you cant is because there is no tunning for the transmission. My garrett kit fit like a glove and drilling for oil is easy. Just follow teh garrett kits instructions for tapping oil. Heres a pic of my setup.
Old Dec 28, 2008 | 05:15 PM
  #38
mrsilent13's Avatar
thats exactly what i did, except my turbo kit i pieced together...using a garrett turbo and universal piping
you can tune your transmission with trifecta
Last edited by mrsilent13; Dec 28, 2008 at 05:15 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 05:23 PM
  #39
how big is the pipes?
Old Dec 28, 2008 | 05:30 PM
  #40
mrsilent13's Avatar
I use a combination of 2.25" and 2.5" piping.3" intake..but i think the garrett kit uses a combination of 2.5" and 3"
Old Dec 28, 2008 | 05:51 PM
  #41
Jn2's Avatar
Jn2
I'm ussing 2.5 pre-intercooler and 3" after it, funnel intake with mesh for filter
Old Dec 28, 2008 | 06:09 PM
  #42
thats kool
Old Dec 28, 2008 | 08:37 PM
  #43
xCobalt05x's Avatar
actually, you cant see the turbo from the back, lol. haven't you seen my dyno video.... just click on my 258whp underline and bold print in my sig, will take you right to it and you can def see the turbo is well hidden.... here are some pictures taken after the turbo install was complete
you did go w/ a forged motor right? i cant remember. if you dont, a rod is going to snap at 250ish wheel torque (on the 2.2) depending on what turbo you are using 300 will be easy to get. I'm an automatic running 10psi and i made just under 260whp. I dyno'd at 258.94 to be exact.
do the 20% loss for being an automatic and this is what im at @ the crank for HP
323.68chp - 20% = 258.944whp
Last edited by xCobalt05x; Dec 28, 2008 at 08:41 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 08:44 PM
  #44
mrsilent13's Avatar
yes im forged and built...so once i get a good intake manifold im going to push about 16lbs..and later ill get some meth and push for mayb 20lbs
get rid of that of your badges and your car will look cleaner
and also not a fan fo your tail lights
Last edited by mrsilent13; Dec 28, 2008 at 08:45 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 08:46 PM
  #45
xCobalt05x's Avatar
i know 2 guys out here in VA that are pushing 18lbs on their 2.4 SS/NA's w/ the stock intake mani
Old Dec 28, 2008 | 08:47 PM
  #46
Sw4y1313's Avatar
You should be fine on 15psi on the stock intake manifold for some time. Thats what im trying to run, but it keeps snowing so i cant take my car out on the roads.
Old Dec 28, 2008 | 08:51 PM
  #47
xCobalt05x's Avatar
once i finish building my forged motor im going w/ the vulcan turbo intake mani and going to run 22lbs and try to get 460-470whp but i'm thinking that ill probably only get to about 450whp so im going to have to use the cryO2 kit to get me to where i want it at.
Old Dec 28, 2008 | 08:58 PM
  #48
mrsilent13's Avatar
yea but those are 2.4s....im a 2.2...different mani...
so ive heard...but i really dont like this plastic manifold or the 2.4 manifold at all....to me it just seems like a plastic explosion ready to happen
ill be happy once i put down at least 300whp safely
Last edited by mrsilent13; Dec 28, 2008 at 08:58 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 08:59 PM
  #49
xCobalt05x's Avatar
swap to the 2.4 mani, i already have
Old Dec 28, 2008 | 09:04 PM
  #50
mrsilent13's Avatar
i dont want a plastic mani....im thinking about doing a lsj IM....with a supercharger delete kit...what do you guys think of that
