2.2L blower cams..
yeah they got deeper grinds, but if you want turbo get the turbo cams, I had a stage 2 cammed balt and was going to put the m62 on it but i went another route to just buy theSS
lnf turbo wouldnt be way to small, its on l efficient on the lnf bc of their direct injection, wouldnt do us 2.2's a lot of good, atleast not anything your procharger coudlnt already do by itself. I would say get the turbo cams and sell me your blower cam set :p
ps. do you have a lope at idle? does it sound cam'd? lmk :P
But the LNF turbo will fall on it's face around 6500(assuming you are going with a stock K04). If you wanna twin charge get a t3/t4 56trim or even just a t3, with the existing blower on there you should be able to run damn close to 400hp. To exceed that you may need to go with a gt28rs(Disco potato) because you will already have plenty of pressure to spool off of with the instant boost of the supercharger.
When I eventually go boost I plan on 450 crank and am probably going to pull a DSM move and take a duramax truck turbo, that will have no problem with the power goals I want it just might take a little while to get there.
ThoR294
Oct 4, 2015 08:44 PM
