2.3 l61?
and maybe i will explore that as an option.
No, I mean single pass. Where the inlet is on the drivers side of the manifold and the outlet is on the passenger side.
Exactly. Although using 4 inlets and 4 outlets would be a pain in the ass, IMO. I like the way ZZP has theirs set up, with just 1 inlet and 1 outlet.
im not sure, the car is automatic for now so that will suck down numbers pretty bad, but id like to put down close to 300 with the m62 blower. cams, ported lsj head, 90mm bore and 94.6 mm stroke, and a single pass intercooler with a 2.8 pulley, i dont think 300 is an unreasonable expectation.
im using eagle h-beam rods, the L61 version, this build is pretty standard with the exception of the sleeved block, that allows me to go to an unnaturaly large bore size, 90mm, that will make the stock l61 stroke a 2.4L.
ThoR294
Oct 4, 2015 08:44 PM
