2.4 mani HELP
i bought mine from CED and it came with everything here's the gasket part numbers you will need
12600729 x1 (sits in opening of the intake manifold for TB)
24455112 x4 (one for each port)
you will also need a spacer plate that CED sells to adapt the 2.2 TB on to the 2.4 TB and that has a gasket as well but i think if you order the spacer plate it comes with the gasket, a brake booster cable, and gm part # 12589516. i hope that helps this is just everything that CED sells for the proper install i haven't installed mine yet because its too damn cold outside but that should be everything else you need if you just bought the 2.4 mani
i have the 08 2.4 manifold which is a little bit different that the one at ced
i dont have any #'s yet im going to dyno sometime next month im trying to get a tune first but you can definetely feel the loss of torque on low rpms i have an auto which makes it even worse when i get the dyno sheet ill post it here so you can see what im talking about bottom line though is that after the 2.4 manifold and the catback the car feels so much quicker i dynoed 122whp with just a K&N SRI this time im hoping to get to 135 maybe less maybe more though i dont know
I noticed a little bit of low end loss, to some it might be pretty annoying, and you will also lose MPG because you have to go into the higher rpm range anytime you're climbing a hill, etc. That and the fact that you'll be on the throttle too much.
are you an 08 as well???
Alright guys thanks for the info.....update time.....Im a service manager so I have awsome access to cheap prices on oe gm parts from the dealers in my area so I ordered all the stock gaskets for the 2.4 mani they are now on my desk at work......and the mani is supposed to ship soon I hope from gmpartsdirect...I ordered it a day ago and it hasnt shipped yet.....Im anxious as hell!!!! Yzrider452 has it on his balt and ive driven his car and it definitely comes alive after 4grand......plus the low end power loss isnt too noticeable between his car and mine.....its there but not too bad at all..... plus I already have my foot in it all the time so I wont notice!!!!!LOL
help
I just ordered this manifold for my 2.2, what you guys are saying that the only way im going to feel a difference is after 4000 rpms exactly what will I lose? Im just an everyday driver who likes the thrill of speed here and there so is this worth it or not?
