2.4 throttle body question
http://www.gmpartsdirect.com/catalog/frameset.cfm
i found throttle bodies for all cobalt engines hope this helps
the 07 2.2 to 2.4 TB......is there any rewiring?
everything is there including the TBs
what about the LS4 t/b's ?
never mind, found it. 159 for a new one on gmpartsdirect
and it apears to have the same bolt pattern as the 2.4 t/b. hmmmmm i may just go to a junk yard and pick up an LS4 t/b just to see if will w/ no modifications, i.e. adaptor plate. hmmmmm ill keep you guys posted. I already know the correction value for Vince to use as a starting point for the idle air field.
the LS4 bolt pattern is the bottom intake mani in this picture... the top mani is an LS2 intake mani
i thank you for the part numbers but for the extended brake hose i can buy it form gm partsdirect too? and LE5 Intake Manifold (Part# 12587878)
PVC Seal (Part# 12589516)
Extended Brake Hose (art number?)
Throttle Body Seal (Part# 12600729)
thats seriously all i need to do the swap instead of buying the kit from CED
vince and i may do this in person when i get a 2.4 tb...i have been tuned by him and have a dyno of the current, but i need some cash for the dyno and buy the tb/adapter plate
Order all of the parts separately from gmpartsdirect.com IF you have 07+ cobalt.
this only works for the 07+ bc 05-06 need the adapter plate and might as well order the kit off of CED
order the following:
Extended Brake Hose
total w/ shipping comes to around $185.
beats the $230 that you would pay with the CED kit.
Extended Brake Hose
the throttle body seal is well, the throttle body seal. thing is that i expected the other one to be the 4 ring seals for the manifold-head connection. what i got was a small metal plate (with a hole in the center) with a seal around it. im sure i can re use the ones i have, but im afraid that i will rip them swapping them to the new manifold.
its the thing inbetween the plate and the other seals.
does anyone have the part number for the 4 other seals?
yes there is a difference. i have pictures somewhere that show the diff in diameter and bolt pattern...i aslo was the first to run it on the 2.2l and get it running with a tune.
and just so i know what i need i have a 06 so i could use an 05 or 06 2.4 tb and can i use my old pigtail connectors or am i going to have to strip those and run the wiring from the 2.4??? i just want to be a 100% positive in what i need before i go to the junkyard and end up with a paperweight
I do not think so
I have the 2008 2.2 and the wiring is a 6 pin. I got a 2.4 throttle body (2007??) and it has a 8 pin plug assembly.
I was going to install it and tune it today but now that aint gonna happen.
