2.4l Intake Manifold Installation Help
S!
I am installing a 2.4l intake manifold on my 2.2l. I have disconnected everything but the brake booster hose. I released the black ring that holds the hose to the booster but can't remove the hose from the booster. I need your tips on how to remove the hose from the brake booster without breaking something. It appears that the hose would just slide off but it is on the brake booster very tight. When I pull on the hose to remove it, the booster itself begins to move or in a way bend. I don't want to break it. Or is that even correct? Where to hose is connected to the manifold, I tried turning in 180 degrees as mentioned in Maven's how-to but it doesn't completely turn enough for me to unlock it. Any suggestions?
Thank you,
INTENSEL61
Thank you,
INTENSEL61
Don't pull it off of the booster, pull it off of the manifold.
When I installed the manifold a while back, there was a 2.4 brake booster hose in with the CED kit. You cut your stock hose and install part of the 2.4 hose on the 2.4 manifold because you need a longer hose with the 2.4 manifold. If you don't have a kit, you will need to pick up an extra length of hose with a male-male adapter to connect your stock hose to the new section.
Hope that helps.
Hope that helps.
you HAVE to pull it off the booster cause it needs to be made longer
and just pull like **** and it will come off, its just a push fit
to put it back on reverse
do not due this! you will/can create a problem in the line...probly not but why gamble...this will probly cost you more too...just pick up a longer hose and replace....prbolem solved
Hope that helps.
Hope that helps.
Last edited by NWAE Cobalt; Apr 1, 2010 at 09:06 PM. Reason: Automerged Doublepost
will the zzp 2.2 cat-con downpipe bolt-n to the vibrant header?
https://www.zzperformance.com/cobalt=540&catid=155
i need to know this quick !
Flyy, what do you mean by cat-con? I would think any aftermarket DP should bolt to and aftermarket exhaust manifold. ...And all your link fail are belong to me! 404 friend.
https://www.zzperformance.com/cobalt...=540&catid=155
yeah idk y the link isn't working bu w\e anyway thanks for the advice though i was thinking that any after market dp would work as well i just wanted some clarification from another person that owns a cobalt, and cat-con is catalytic converter
Note to NightHawk...the 2.4 brake booster hose IS a 2-piece set up. There is a connector in the center from the factory. To install it on the 2.2 with a 2.4 manifold you only have to cut the 2.2 hose in the right place, split the 2.4 hose assy at the center connector, and install it in the cut 2.2 hose.
i have NEVER seen or used a two piece setup
just do it RIGHT the first time, and go pick up a sub 5$ piece of hose and replace the whole thing
Have you seen a 2.4L booster hose? They are a 2-piece hose with a connector in the middle -- that's the way they come. The one on my 07 2.4L SS was that way and I installed one on my 06 2.2 LS. The 2.4L booster hose has the bends that make it look "factory" instead of running a straight piece of hose. Either way works...just depends on how you want it to look.
