2005 2.2l Cobalt Engine Mounts
Old Aug 7, 2008 | 10:16 PM
BoostedEco's Avatar
I have searched around here for a while and haven't really found the answers I need.
A friend of mine has a 2005 Cobalt 2.2l (w/ several bolt on modifications) and we have found on Gravana tuning that the Ingalls Torque damper will work with a certain stock motor mounts. The short spread mount to be exact.
My question is this, what does a "Short Spread" motor mount look like? Gravana stated some, not all 2005 models came equipped with the "old style" mount.
Could someone post a picture showing me which mounts are which? Gravana also stated that the old style mount can still be used but we would need to purchase some parts from GM.
Thank you to whoever can clear this up for us.
Old Aug 7, 2008 | 10:46 PM
TurboTechRacing's Avatar
Post or PM us picture of your mount, this is the only true way to tell. Also you will be much better off getting the solid engine mount. The Ingalls has been known to "bend" the brackets... Many members have used the Ingalls and then switched to the Turbo Tech Racing Solid mount and stated they would never go back to an Ingalls.
Might save you some $ in the long run.
Old Aug 7, 2008 | 10:49 PM
Rodimus_Prime's Avatar
If your making enough power to justify motor mounts, get the solid ones not a band aid
BoostedEco's Avatar
I saw the product on your site, I spent like 3 grand on your site when I built my eco, so I was telling my buddy to get the turbo tech raciing upper mount we just need to make sure it fits
Old Aug 8, 2008 | 06:07 AM
Jn2's Avatar
Jn2
if you buy TTR's mount, it dont matter what mount you have now, it will bolt up fine with no problems, as you are replacing the whole mount...
Old Aug 8, 2008 | 08:02 AM
BoostedEco's Avatar
then whats this mean?
*Note for 2.2/2.4L Cobalt models with the "old style" mount (found in some 2005 models):
You may need to order the following parts from your local GM dealer (GM Part Numbers):
Bracket (qty 1) #15854396 List Price $32.50
Bolt (qty 2) #11514280 List Price $4.25
Bolt (qty 1) #11516330 List Price $4.04
Bolt (qty 3) #11518166 List Price $1.47
Old Aug 8, 2008 | 09:47 AM
Yes, so please post a picture and if you do have the old style mount, you will need to get those parts. They come to around $30 at a dealer so it is not bad...
Old Aug 8, 2008 | 12:34 PM
Black08SSTC's Avatar
subsribed for possible 07LT solid motor mount purchase
Old Aug 8, 2008 | 10:20 PM
BoostedEco's Avatar
here we go, sorry for bad picture we dont have a digi cam
Old Aug 8, 2008 | 11:16 PM
Yeah you need the GM part numbers we list you have the old style mount, which GM does not use anymore on the newer cobalts.
Old Aug 8, 2008 | 11:37 PM
BoostedEco's Avatar
ok i will let him know
Old Aug 14, 2008 | 11:08 PM
BoostedEco's Avatar
Having a problem, gm parts direct cannot find the part number for the bracket, is that the correct pn?
Actuallly they can find the part once I dug a lot deeper but they do not list a price, does anyone know of another location to buy it?
Old Aug 15, 2008 | 07:05 AM
All the parts from a local GM dealer should come to about $35.00
Old Aug 15, 2008 | 08:00 AM
BoostedEco's Avatar
Thats not the issue, the issue is the part number for the bracket you have listed on your website no longer is found in GM Parts Direct, or through my dealer. So I basically have a $200 mount and can't put it in yet...
Old Aug 15, 2008 | 11:24 AM
I think it was you that emailed me... I sent you a photo of the "GM Parts Direct" catalog page with this bracket. It is there, they just do not list the part number online for some reason. Everyone else has always got it from a local GM dealer of theirs. It wont be on their shelf (takes a week to get)
Old Sep 21, 2011 | 10:04 AM
IonNinja's Avatar
Does anyone know the bolt sizes for these GM part numbers?
I'm finally switching over to the new style mount and would rather try to get these from an auto parts or hardware store
Old Sep 23, 2011 | 01:46 PM
GpB311's Avatar
I bought the bracket and bolts from gmpartsdirect when I installed my TTR engine mount. They were on sale too, so it was more like $20.
Youll need to jack the engine up a few inches to replace the bracket, but as long as you support it with a jack and wood between the jack and oil pan or something, youll be fine.
You can kind of see here how on the new mount and bracket, the 3 bolts are much closer together.
Old Sep 23, 2011 | 02:13 PM
Powell Race Parts's Avatar
the F23 rotated engine mounts we make work for Cobalts and Ions; replacing the upper bracket like that on the passenger side is really pretty but in tems of function for mount alignment and wheel hop, does not help.
Ingalls torque damper does not help either.
Old Sep 23, 2011 | 09:35 PM
IonNinja's Avatar
thanks for the reference pics...I might consider trying to get the parts from there if no one else responds
and i'm not looking to make the switch for performance reasons...I'm doing this because the LSJ tensioner literally does not fit with the old style mount and I would finally like to ditch the hacked up mount/bracket that I've been running
Old Oct 20, 2011 | 03:49 AM
IonNinja's Avatar
new style mount installed
Spanky's Monkey
Mar 7, 2016 06:06 PM
TurboTechRacing
Oct 27, 2015 07:58 AM
brett.higgins3
Sep 14, 2015 01:48 PM
Josh@ottp
Sep 5, 2015 07:46 PM
