200whp N/A?
Old Dec 19, 2010 | 03:50 AM
  #426
o3nisoaso3's Avatar
Hi.
Take2-08LT Read vbgarage
Message if specific details are wanted
Old Dec 19, 2010 | 07:35 AM
  #427
HunterKiller89's Avatar
Originally Posted by newt
Sleaves are good to around 400whp, after that things can get ugly.
depends on the block really, but this is true for L61's, yes
Old Dec 19, 2010 | 08:48 AM
  #428
huckernage's Avatar
Boring a 2.2 isn't the best idea, the sleaves are thin as it is. No real videos from the outside but I do have this sweet in-car vid....
YouTube - pontiac sunfire drag races 13.8 sec quarter mile, all motor, for my friend dave K the legend!
your car sound empty
is your rpm limiter set 7700+. you finish ź in third gear.
what is your mods?
Old Dec 19, 2010 | 04:47 PM
  #429
newt's Avatar
Car is gutted from the front seats back, i have a cut-out tho...hence why its so loud.
Limiter is set to 7600rpm, I shift at 7500rpm and cross the traps at almost exactly 7000rpm in 3rd gear at 100mph.
Mods:
comp stage 2 cams
LE5 IM
Bored TB
4-1 Header to a cut-out
WAI
Balance Shaft Delete
Old Dec 20, 2010 | 05:18 PM
  #430
alanoo's Avatar
Originally Posted by HunterKiller89
well if you bore it you'd have to sleeve it. most modern alum GM engines only have enough sleeve diameter for a clean up hone/bore, not a bore meant to increase displacement
The 2.4 LE5 has the exact same sleeves and it is OE reliability validated at 88mm bore...
Truth is, the Eco sleeves are in the thickest ones of this type, honda K20 ones are much thinner for example
Old Dec 20, 2010 | 05:19 PM
  #431
huckernage's Avatar
Mods:
comp stage 2 cams
LE5 IM
Bored TB
WAI
still few question about your setup.
WAI?
what is your header?
light flywheel or not?
drag radial or slick? PSI? rim dia.?
is it still your daily drive?
is balance shaft delete make your car less comfortable? is my GF ll notice it?
which track did you run in Ont.?
i try to understand why you are 0.35 and 6 mhp faster that me.
i thing you have a good track and wind in your back
Pont rouge dragway is againts wint 90% of the time and get higher by 3'
your front end has a better drag coefficent.
next year, we could meet at napierville for a duel.
Old Dec 20, 2010 | 06:52 PM
  #432
newt's Avatar
Yes, WAI.
Header is a OBX-R (Ebay gold) 4-1
Stock Flywheel and Clutch
M&H Cheater slicks 25x8x14, I run them around 15psi
Not my official daily, but I do drive it to work alot and the the drag strip thats 5 hours from my house and I drive it there.
There are a bit more vids, I have all aftermarket engine/trans mounts so I think its more noticeable. Also with no interior everything vibrates more, so its hard to tell how it would be in a stock interior car.
I made those runs at Cayuga, I race the bracket class in CSCS every year.
I don't get out that way much, I was going to go to the CSCS out there this summer but didn't get around to it, my buddies went tho. We ussualy just race St. Thomas and Cayuga. I'm from Sudbury.
Next year I hope to be in the 12's on the motor...haha I'd still love to line up against another all-motor eco tho!
Probably has a lot to do with the weight, do you know what your car weights?
WAI?
Old Dec 20, 2010 | 07:16 PM
  #433
huckernage's Avatar
yes but what is WAI?
Old Dec 20, 2010 | 08:02 PM
  #434
newt's Avatar
warm air intake
Your car weights 1120kg?
Old Dec 20, 2010 | 08:09 PM
  #435
huckernage's Avatar
yesser
Old Dec 21, 2010 | 04:02 AM
  #436
all_motor_mike's Avatar
did my post get deleted or did it just not go through? anyways i said i did .040" over on aarons turbo build and hes had no issues yet with about 2k on the odo. the sleeves are quite thick on these as alanoo said there should certainly be no issues on an NA setup.
mike
mike
Last edited by all_motor_mike; Dec 21, 2010 at 04:02 AM. Reason: Automerged Doublepost
Old Dec 21, 2010 | 06:36 PM
  #437
NWAE Cobalt's Avatar
mike
mike
do you know what that would make the overall size of the motor at that point?
Old Dec 21, 2010 | 06:41 PM
  #438
ok, so it looks like that would make it a 2.3l engine
Old Dec 21, 2010 | 06:48 PM
  #439
.040 over is just about LE5 bore, 88mm. I think the stock stroke is just under 96mm IIRC, i know the LE5 is an 88x98mm and all the non 2.4l motors use an 86mm bore
for reference the GM racing block is an 89x89mm 2.16L
Old Dec 21, 2010 | 10:10 PM
  #440
stock diplacement is 2196cc (aka 2.2L)................ .040 (1mm) over puts u at 2248cc. so u pick up a whopping 52 cc and thats not enough in my book to call it a 2.3 L. call it a 2.25L lol!
mike
Old Dec 22, 2010 | 10:38 AM
  #441
that works
i cheated and used an online calc for it :P
Old Dec 22, 2010 | 09:13 PM
  #442
DarkChild's Avatar
warm air intake
Maybe you and I could meet up sometime next year. I haven't gone to Cayuga but always go to St.Thomas. Anyway, OP... I believe anything is possible with money.
Old Dec 22, 2010 | 11:24 PM
  #443
D-mac's Avatar
Need to get some more Drag Racers to the CSCS events
Old Dec 23, 2010 | 03:06 AM
  #444
o3nisoaso3's Avatar
tom you get any new things done w/ ur car recently? i cant wait for spring to get some vids of my lil baby. she be a monster..... for n/a haha good thing shes built for 600whp w/ the turbo kit im gonna be running
Old Dec 23, 2010 | 03:14 AM
  #445
just CF hood...replaced engine last spring. port and polish head this winter hopefully. then re dyno tune with vince
Old Jan 7, 2011 | 11:21 PM
  #446
DarkChild's Avatar
I'm always up for it. That's for a different thread though. If you bore it out to almost a LE5 you should net your goal. I've seen bolt on LE5's put down some aggressive numbers.
Old Jan 7, 2011 | 11:23 PM
  #447
Leafydialupking's Avatar
Or just snag an LE5 from the junk yard, use an LE5 hg and it should be a bolt in process of putting your head on that bottom and and into your engine bay.
Old Jan 24, 2011 | 03:23 AM
  #448
mkriebs's Avatar
Still in the race for 200whp huh? Glad I am not too late... Or, is this only the 2.2 crowd? 2.4 DQ'd from this?
Old Jan 24, 2011 | 05:14 AM
  #449
2.4 welcome, but we prooobably wont appreciate it as much. But still, I'd like to see it done.
Old Jan 24, 2011 | 08:15 AM
  #450
mkriebs's Avatar
I'll just shoot for 250 then
GaryGibblez
Jan 14, 2020 10:35 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
