35 to 135 psi
Old Apr 6, 2006 | 08:42 AM
Probalt316's Avatar
35 to 135 psi
Can anyone out there give me any more info on this product to me it seems as if u would use it with a s/c but i think its for a stock engine
Im curious if it would void my warranty and if there are any significant gains i would get out of buying it
http://www.gravanatuning.com/applica...sure_Riser_Kit
Old Apr 6, 2006 | 08:44 AM
3fo893013L's Avatar
that wont' really give much gains I don't think... I think it's better for F/I to allow better fuel delivery. On a 2.2L N/A with not much done isn't going to provide anything. Just being realistic
Old Apr 6, 2006 | 09:06 AM
Roadrunner's Avatar
wait till you have boost, or are in the process of building for boost.
Old Apr 6, 2006 | 12:48 PM
slowion2's Avatar
keep in mind, you also usually run those on fuel systems with a return line, and I know Ions don't have them and pretty sure Cobalts don't either. For someone looking to replace their fuel pump though anyway when building for f/i, it might not be a bad idea to add to their fuel setup.
Old Apr 6, 2006 | 11:58 PM
dnbguy86's Avatar
You gotta think though for a second, on a stock fuel system which im assuming you have, if you raise fuel pressure past 60-75psi, the regulator will bypass it and will send it back to the tank via return line. But, cobalts have returnless fuel systems so raising fuel pressure on a stock vehicle will yield pratically no gains...im almost damn sure we have returnless systems, but its to late at night to go check plus i dont feel like it right now lol.
Old Apr 7, 2006 | 12:19 AM
Clmbngfrk18's Avatar
if you click the instrutions they seem to be very detailed maybe we due have a retunrn line i mean it gives bolt sizes so they must have test fitted
Old Apr 7, 2006 | 09:42 AM
slowion2's Avatar
exactly
just because a company lists a part or a car doesn't always mean it will work on it. companies like to think that other models are all the same as some new ones because they share the same engine.
Old Apr 7, 2006 | 09:53 AM
fire_cky's Avatar
unless you're running boost, that product will ef up your air to fuel ratio and you'll probably lose power.
Old Apr 7, 2006 | 12:21 PM
D4u2s0t's Avatar
well, it claims 6 hp, which means it will reallisticaly be less than that, and for the same price you're better off getting a CAI
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
