6500k rev limiter
6500k rev limiter
is there a safe way to change rev limt i thought i read a while back about someone changed to 7000
I'm old school
Actually, the valve train on the LSJ and L61 are identical except for the sodium filled exhaust valves. And thats just for heat, not RPM's. You can spin a stock L61 to 7000 without issues.
But the above posts are correct about tuning. It's just not available yet.
can you really? I thought we were at our limit as far as the valvetrain goes already
so I could get a set of cams & up the limiter to 7K without a valvetrain upgrade huh...
even better, less money spent...
My question is, is that extra 500 RPM's really gonna do much power wise for the 2.2?
I have one, and even at the 6500 red-line, it doesn't pull anything at that high of
an RPM range.
If someone could answer this that would be great cuz I would like to know.
Thanks guys.
an RPM range.
Thanks guys.
stock no it wont do **** for you...you don't even make power all the way to 6500 so upping it to 7K would just slow you down.
Its pointless without a set of cams to shift your powerband upward...
your merely stock on with maybe a few bolt-ons.
Thanks for the feedback Ion.
With that kind of RPM I would think that the entire exhaust system would have to be changed to and SS/SC system or better. There wouldn't be enough flow in the stock manifold cat and downpipe to justify it. Anyone else have an opinion on that, I just don't think the motor could breathe and probably float a valve.
z28addiction
09-28-2015 12:03 AM
