All Motor?
All Motor?
Okay I have an 07 Ls auto. And I have seen that they dont make aftermarket cams for our car yet because something to do with cam sensors and how they want to make the car fuel efficent or some crap. But I was looking at the patriot performance heads and they have the stage 2 Ecotech assembled with cams. will that work. Im also going with internals also thats usally what you do if you buy a ported head lol I would use the same 2.2 block right and is there any way to make the block stronger? And Pistons and connecting rods forged crank shaft valve springs and the head stud kit. Has anyone done this build or anything close to it
Another thing is Compression Gaping for pistons, and Tranny i have an auto tranny i heard it hold up better than the manual's. And i know tuning is a must also. And torque the bolts while building. But another thing is would i use the 2.4 intake mani. And my mid length header dp. Or would i have to with something bigger exhaust wise. I think im missing some **** but im just trying to get this thrown out there. Im trying not to be one of dudes that get on here and just say they have all these parts and just dont know nothing. Im just trying to learn more about this build and see if anyone has done it and i do use the search button lol but if any one can help out a semi newb throw in your input about it. Thanks for everyones help for me on this site so far
cam sensor is computer related the head will work but you will need a custom tune for the cams to work. and your exhuast will be fine. once you're boosted you may want to run larger piping but for a N/A build that's perfectly fine. the block is not your weak point in the build you listed and other members have built their engines up in the same way to run boost. look for misfitcobalt or yellowshowbalt for answers and make sure you get turbo cams for that turbo build. i have found out that staged cams are too aggressive for the boosted build.
haha sweet thanks everyone im pretty stoked about this build i think im gonna order the stage 2 patriot head sometime next week. I still dont know if im gonna go F/I yet i just wanna see what numbers i get. But there is alot of work ahead. Would anyone know about compression
Does anyone have the patroit head on there cavy or balt if so what bore size on your pistons are you running..
Last edited by BlackBoltSS28; Jul 3, 2008 at 03:40 PM. Reason: Automerged Doublepost
Sweet thanks thats the answer im goin for lol. that buid in you sig is gonna be sick man good luck with it you know your **** haha
Would anyone know where to get pistons rated for 11:1 or 11.5:1 the biggest i found is 10:1 0.20 over bore. im trying to get all this together im goin all motor and see the numbers i get. Thanks for the help everyone
Last edited by BlackBoltSS28; Jul 3, 2008 at 07:51 PM. Reason: Automerged Doublepost
Your going to have to go custom for those compression ratios. Talk to Wiseco they have great prices on custom pistons, so does JE Pistons. They both have the L61 piston specifications so you wont need to provide anything. Just make sure you specify its for a NA build. I know JE makes them completely different if its for NA versus FI.
Yes thanks man. I know ppl say our trannys are strong but i dont think just having a shift+ will help i found after market flywheels on CA but i dont know if those are just for manual trannys and auto's
ThoR294
Oct 4, 2015 08:44 PM
