ARP headstud torque???
Old Jun 25, 2012 | 02:20 AM
1LowLS's Avatar
What are you guys torquing your ARP 7/16ths head studs to?????LSJ should be the same as well.Manufacturer recommendations or???
Old Jun 25, 2012 | 03:39 AM
Omiotek's Avatar
i usually go to 90 ft/lbs. the specs call for 85 i think but i do it in increments of 3. 30 ft lbs then 60 ft lbs then 90 ft lbs in the correct TORQUE SEQUENCE.
Old Jun 25, 2012 | 04:07 AM
Allgood Customs's Avatar
mine said 18 pounds then 150 degrees
Old Jun 25, 2012 | 08:56 AM
1LowLS's Avatar
For ARM studs^^???
I actually found it on ARP's site. 3 pass's of 80 ft lbs in the correct sequence.
Old Jun 25, 2012 | 12:14 PM
bluebalt07's Avatar
That's the stock head bolts and it's actually 22 ft lbs plus 155 degrees
Originally Posted by 1LowLS
For ARM studs^^???
That's it. I went 40, 60, 80 in the sequence and holds perfect.
Old Jun 25, 2012 | 02:13 PM
just retorqued mine
Old Jun 27, 2012 | 11:01 PM
BankerBalt's Avatar
Did anyone have a problem where not all of them were at the same height when finger tightening them? Almost like the threads got stretched?
Old Jun 27, 2012 | 11:05 PM
OttawaMark's Avatar
Some probably just didn't bottom out in the block.
Old Jun 27, 2012 | 11:09 PM
1LowLS's Avatar
I used a allen wrench on a 3/8 drive to put them in the block but didn't torque them.Just put them in loosely with the socket but they are all the way down and even.
Old Jun 27, 2012 | 11:47 PM
BankerBalt's Avatar
see, mine are all going down different depths. and it's really bugging me because i wouldn't want to **** up a tap...
Old Jun 28, 2012 | 12:16 AM
OttawaMark's Avatar
I've read they go in until they bottom out and the back off 1/4 turn, if they are different heights you need to tap em good and slow.
Old Jun 28, 2012 | 12:17 AM
BankerBalt's Avatar
anyone got any recommendations? either heat/cool the studs and fit them in or should i tap the holes in the block with a 7/16 thread?
edit: what type of tap would you recommend because i've been told most taps don't go that far down...
Old Jun 28, 2012 | 12:22 AM
1LowLS's Avatar
I didn't have to tap mine at all
Old Jun 28, 2012 | 01:01 AM
OttawaMark's Avatar
My head was off, had no problems tapping. I'm guessing your head is still on the block?
Old Jun 28, 2012 | 01:11 AM
BankerBalt's Avatar
Nope. Head off, engines been out of the car for 4 months lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
TedSS
26
Oct 10, 2015 04:30 PM
Sep 27, 2015 08:53 PM
