Automatic Shifter light fuse location
Old Apr 10, 2012 | 07:27 PM
znew's Avatar
I have searched the fuse diagrams and can't seem to find where the fuse is for the shifter lights on an automatic cobalt. Anyone have any idea where the location of this fuse is.
Old Apr 10, 2012 | 07:44 PM
LS6Rally's Avatar
i would think it would be with the cluster lights or headlights. its not normally lit all the time correct? i have a 5 spd. so im not sure. do you have a test light?
Old Apr 10, 2012 | 08:01 PM
BLKLS's Avatar
More then likely, it's power is tied into the power for the cluster. If you want it to stay out you'll probably have to pull the cluster out and remover the bulb, unless it's an led then your beat.
Old Apr 10, 2012 | 09:08 PM
znew's Avatar
it comes on at night but it burnt out to where you cant see it.
Old Apr 10, 2012 | 10:35 PM
bluebalt07's Avatar
Probably in one of the places that's already been stated or one other place you could check is the interior light switch. If you know it's burnt out though why do you need to mess with the fuse, should just need to change the bulb
Old Aug 26, 2019 | 09:15 PM
Chris Works's Avatar
Did you ever figure this out? I have the same issue...
Old Sep 3, 2019 | 11:26 AM
Bdawg977's Avatar
Should be in the shifter assembly i'd think or underneath it
Squints
Dec 2, 2012 08:24 PM
stormtrooperxl
Nov 16, 2011 12:38 PM
DEZZIE41
Feb 6, 2011 12:26 AM
sjc0013
Dec 22, 2009 11:14 PM
bbbevans89
Nov 4, 2008 08:21 PM
