Boosted 2.2 look here
Old Jan 14, 2009 | 10:34 AM
pykie's Avatar
I know there is a few of yea out there, can you post pics of where you have you Mass Air Low Sensor at.
is it before or after your blowoff on your charge pipe? or is it on the intake pipe?
Old Jan 14, 2009 | 11:33 AM
Sentry's Avatar
You can do either. Draw through (through the turbo intake) is only if you're going to be recirculating the bov back into the intake piping. The more accurate approach is blow through (after the compressor housing at the charge piping) and more specififcally after the BOV. If you do it before the bov you're just dumping metered air and you'll run a little rich between shifts/gears.
Old Jan 14, 2009 | 11:36 AM
brickerenator's Avatar
mass air low?
Old Jan 14, 2009 | 12:10 PM
BlackCobalt707's Avatar
wow, i didnt even think to look into this, thanks
Old Jan 14, 2009 | 12:11 PM
ilovecars's Avatar
yea i would def say after the bov
Old Jan 14, 2009 | 12:17 PM
pykie thanks for bringin it up, everyone else thanks for the answers
Old Jan 14, 2009 | 12:51 PM
b_faulk75's Avatar
Just wondering where i could get a blow thru maf sensor?
nother question, Where in the piping should i put my Atmosperic BOV, before the intercooler or after it?
Old Jan 14, 2009 | 02:41 PM
pykie's Avatar
Thanks that helped alot.
Old Jan 14, 2009 | 03:25 PM
ilovecars's Avatar
what kind of maf is that? the not block one? i would also like to get that kind. but as for the bov most people do it after the intercooler
Old Jan 14, 2009 | 04:18 PM
mkulrey13's Avatar
Heres my bay.
Old Jan 14, 2009 | 04:40 PM
b_faulk75's Avatar
MK, Your MAF is in the intake of the turbo, correct? You have the recirculating BOV also, i am wanting to use an atmospheric BOV and am not sure where the best place to locate the MAF in my system is, i am doing a custom setup by the way!
Old Jan 14, 2009 | 06:23 PM
Jn2's Avatar
Jn2
Bov= maf before throttle body, in the cold charge piping, bov in the hot charge piping
Old Jan 14, 2009 | 06:24 PM
WhiteSSBalt's Avatar
Not a Sebring
Your going turbo faulk?!
Old Jan 14, 2009 | 10:12 PM
b_faulk75's Avatar
Huh? Sorry, i think i understand u but not sure!
I'm workin on it!
Old Jan 14, 2009 | 11:12 PM
pykie's Avatar
Okay im running a PIT BOV, so i am assuming its not the recirculating BOV
but still now i am confused.
the colr side of the charge pipe is on the drivers side of the car, and i really dont want to cut my harness to wirethe sensor in way over there...
any ideas?
and if you locate the MAF on the intake pipe do you have to use a recirculating BOV?
Old Jan 15, 2009 | 01:10 AM
Jn2's Avatar
Jn2
U don't have to cut it, I undid the loom to mine and I had enough slack to move it by the ECM
Old Jan 15, 2009 | 01:19 AM
HunterKiller89's Avatar
i did the same for my setup, and it reaches all the way to the stock LSJ intake, in the fender well. Its tight tho, but i doubt you will need t route yours that far
Old Jan 15, 2009 | 01:52 AM
Sentry's Avatar
any ideas?
The bov can be on the cold side, in fact that's where it probably should go. It's all preference at this point. More than one way to skin a cat. I would personally do blow through, bov after IC and then MAF right before the TB.
Old Jan 15, 2009 | 02:02 AM
Jn2's Avatar
Jn2
That what I'm doing my maf pipe from zzp should arrive tommorow
Old Jan 15, 2009 | 10:40 AM
PsychoCam's Avatar
my setup is ran from the intake throttle body down to intercooler and between them two I have my blow off valve
Then other side of intercooler to the turbo.
My maf is on the intake pipe going to the inlet side of the turbo. Is this correct?
Old Jan 15, 2009 | 10:54 AM
pykie's Avatar
Can you send me pics of this set up you have? and the link to the maf pipe from zzp?
Old Jan 15, 2009 | 11:48 AM
Sentry's Avatar
That's all fine, just remember that if you're using a atmospheric bov that you'll be dumping air that's already been registered by the maf. In other words, you'll be telling the computer to shoot fuel when there's no air to combust it. You'll be running rich every time the bov actuates.
Now, if you're recirculating the air back into the intake pipe, you have nothing to worry about.
Old Jan 15, 2009 | 05:18 PM
PsychoCam's Avatar
How would I recirculate it back to the intake pipe. all I know is that my bov is blitz
Old Jan 15, 2009 | 07:38 PM
Sentry's Avatar
Some can't be recirculated, like mine that has an airhorn style outlet. But, most just have a nipple that blow out the air that you can attach a hose to run it to the intake. You might have to drill into the intake pipe and tap it with a brass fitting though.
Old Jan 15, 2009 | 08:34 PM
pykie's Avatar
Okay heres my blowoff valve tell me where to put this and where does my maf go thank you
you can see my newly made shorty antenna in the pic too lol
