Bought my downpipe/exhaust...
Old Feb 26, 2009 | 12:51 AM
Firebirdhorn's Avatar
for us, i think the LSJ is perfect, but i am no guru of GM parts. It is however very hard to find someone that will sell you their LSJ downpipe. Hopefully in the near future i will have mine on, to accompany my 2.5 magnaflow catback.
Old Feb 26, 2009 | 03:13 AM
HunterKiller89's Avatar
Originally Posted by kkanowitz
Egh...so basically I'm killing the whole powerband? ****... Well see I already have the 3" sitting here at my house...
maybe a couple horses down low, and no gain up high...so yea, pretty much, but you wont really notice those losses.
Old Feb 26, 2009 | 11:58 AM
philupondes's Avatar
what would be a far price for a used lsj dp? and you do think there will be power gains from lsj dp as compared to the stock l61 dp
Old Feb 26, 2009 | 01:14 PM
^ not much..$50-$75, and yes
Old Feb 26, 2009 | 02:09 PM
mkulrey13's Avatar
yea the 3" is WAY to big for a NA 2.2. Im running 3" and im well over stock power level get a LSJ downpipe, 2.5"
Old Feb 26, 2009 | 05:13 PM
bikeboyben14's Avatar
ive got an lsj downpipe for sale it doesnt have a cat tho, but id sell it for 60 shipped
Old Feb 27, 2009 | 09:16 AM
well the napa guys next to my shop are making my exhaust today, and I just put my header on lastnight so at lunch I'll ride around a bit, O yea dont know if I said it or not but I'm having them run 2.5 from cat no res. to stock muffler, I'm still not sure which muffler I want but I want to keep it low and quite.
^and I want a lsj dp but I want stock
Old Feb 27, 2009 | 11:27 AM
kkanowitz's Avatar
UPDATE: So I got the downpipe installed and for now it's just bolted up to my factory catback. Like I said there was a major exhaust leak in the factory flex pipe and my engine was running so shitty so I had to do something. It turns out that the factory flexpipe completely broke all the way around except for about an inch or so.
Now I busted one of those damn studs that are on the 3 bolt side of the exhaust manifold... So now I gotta take the manifold off and drill it out. Anybody have any advice on doing this?
Old Feb 27, 2009 | 11:34 AM
409Cobalt07's Avatar
i have the same setup on my car, accept i bought the system from magnaflow and the dp for zzp. its going to be really deep and rumble kinda. but it wasnt loud enough so i gutted my muffler and welded it back in. sounds amazing!
Old Mar 7, 2009 | 02:55 AM
kkanowitz's Avatar
Well I finally installed everything. I love the sound. Definitely isn't too loud but when it's wide open it screams. Not even a "rice" type of scream but almost like a V6 I wanna say.
A few problems so far:
- The ZZP downpipe only has one O2 bung. After taking everything apart, I realized that I have two O2 sensors. For now, I have the one after the cat connected, but I disconnected the one before the cat. It's running kinda shitty, so I gotta figure that out.
- I busted a stud on the exhaust manifold when I was removing the old downpipe. I plan on drilling it out and replacing it with a high grade bolt. (hopefully this weekend)
Other then that stuff, it's great. I definitely lost a lot of low end power but higher up seems to be improved, which is okay with me.
Old Mar 7, 2009 | 05:34 AM
  #36
run the o2 sensor before the cat. the one after the cat only checks to make sure your cat is working...its the one before the cat that determines AFR, so plug it in!
most exhaust shops can weld in an o2 bung for like $25 btw.
Old Mar 7, 2009 | 06:57 PM
  #37
kkanowitz's Avatar
Ugh ****. Well I have access to a MIG wirefeed at school...so I may do it myself. I'll buy the bung. And then I just drill the hole and weld it, right?
Old Mar 7, 2009 | 07:20 PM
  #38
i believe so, yea
Old Mar 7, 2009 | 07:24 PM
  #39
Jn2's Avatar
Jn2
if its the wideband bung, the best position for it, it looking directly at the pipe,
between 10pm and 2pm are the best angles to do it, avoid anything on the sides or direct button as moisture likes to build up there
Old Mar 8, 2009 | 11:48 PM
  #40
kkanowitz's Avatar
Sweet. If I would've known this I could have just paid $10 more to ZZP and added a wideband bung, but whatever. So I'll just do that....
Any idea on local places that might have the bung? I went to Checker and they told me only NAPA would have it.
Old Mar 9, 2009 | 01:37 AM
  #41
find an exhaust shop in your area. google is your friend
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
