Camshafts
Old Oct 16, 2006 | 11:27 PM
tricky1's Avatar
Camshafts
A few questions
On JBP they have no cams for the 2.2 under the cobalt section, but on the 3rd gen section they do, I'm just wondering if these are interchagable or not.
http://www.jbodyperformance.com/new/...catName=JP0288
Also with a cam upgrade is there anything else I would need to upgrade? Valve Springs? Seals? etc.
Old Oct 16, 2006 | 11:56 PM
rally's Avatar
No, JBP is currently developing (or getting ready to develop) cams for the 2.2.
As far as cams that can go in the car right now, only Comp. Cams Stage 1 I believe can be placed in the cobalt without tuning. Otherwise tuning is needed to adjust timing.
Old Oct 17, 2006 | 02:46 AM
Roadrunner's Avatar
http://www.levelzeromotorsports.com/...7f704529cab65d
what about these? has anyone used them before?
even the heavy intake grind appears mild compared to comp cams stage 1
Old Oct 17, 2006 | 02:59 AM
NJHK's Avatar
Understand that the 2.2 ECOTECs in all the motors are basically the same. Yes, the camshafts would work in your vehicle. They would physically fit, yes.
As far as them not being available for your application, understand that companies like to develop camshafts that not only fit inside your motor but can "co-exist" with your computer fine. Alot of companies know that the average person who wants camshafts, cares about check engine lights, has their car inspected and isn't out to have a full race car. This is why they come up with "stages". Typically, the lower the stage, the less likely to have any check engine lights thrown cause they cause less valve overlap and have a less of a rough idle.
As far as level zero, their stage 2s have been known to cause thrown codes.
Remember that changing camshafts isn't some small part like an intake that changes airflow minimally. You camshafts are a critical part of the engine and changing them changes how much airflow is being seen inside the combustion chamber overall. With this happening, tuning is important as well. So untill HP Tuners is available, I would either buy them and not install them or deal with having a not 100% running vehicle.
Old Oct 17, 2006 | 03:01 AM
Roadrunner's Avatar
Thanks for posting
do you know anything about Level Zero's Triflow Camshafts? those are the ones that the link is pointing to, not stage 2's
Old Oct 17, 2006 | 03:12 AM
joeworkstoohard's Avatar
they look like regrinds... i've never really heard anything good about reground cams.
also, what's all this business about 2 seperate profiles??? this isn't a V-TEC car...
Old Oct 17, 2006 | 03:17 AM
NJHK's Avatar
Originally Posted by Roadrunner
Thanks for posting
Sorry, I didn't even click the link lol
I have yet to see anyone show any dyno slips or any real complaints as far as they go but I know of one or two people with them. I know Owen Stampflee on the ECOTECForum.com has them and no complaints from him.
Old Oct 17, 2006 | 03:18 AM
NJHK's Avatar
Who said anything about 2 seperate profiles? Maybe I missed it...
Old Oct 17, 2006 | 03:19 AM
NJHK's Avatar
The answer is No, unless these parts are already worn (which I doubt on a pretty much brand new car).
Old Oct 17, 2006 | 03:20 AM
it's in that link's cam description.
Old Oct 17, 2006 | 03:21 AM
if one is going with a slightly more aggressive cam, that's true. if it's something pretty wild, it would always suggest a new set of springs. they're cheap insurance.
Old Oct 17, 2006 | 03:23 AM
NJHK's Avatar
True but I'm also going on a limb and saying that anyone that is going to get something really wild as far as overlap goes is doing more than just camshafts and knows better
Old Oct 17, 2006 | 03:24 AM
NJHK's Avatar
Ah, i see it now.
To be completely honest, I know squat about the Tri-Flow camshafts.
Old Oct 17, 2006 | 03:37 AM
tricky1's Avatar
Ok, well I'll wait for tuning. I'm thinking about going turbo if and or when it becomes available.
Old Oct 17, 2006 | 03:40 AM
NJHK's Avatar
If thats the case, maybe you should hold off till you are fully sure you're going that route just for the fact there are some nice camshafts available for boosted applications.
Old Oct 17, 2006 | 09:57 PM
The_Blur's Avatar
I could've sworn GMPP has a cam set.... Wouldn't GM have some sort of tuning for that?
Old Oct 17, 2006 | 10:02 PM
rally's Avatar
GM offers cam blanks, which you need to get grinded. And no GM wouldnt offer tuning.
Edited because some people are still questioning it when I said it right there. They sell CAM BLANKS which you need to have grinded.
Old Oct 17, 2006 | 10:05 PM
artawesome's Avatar
i believe they do have cams, tuning? not to the public
Old Oct 17, 2006 | 10:13 PM
g5mike's Avatar
I think that the 2.2 cams will follow the ones Im testing for JBP
Old Oct 17, 2006 | 10:31 PM
NJHK's Avatar
For the cams, yes.
For "tuning", nope.
Notice how the GM Performance Book tells you how to reach x HP but doesn't tell you anything about tuning
FYI: The GM race cars use Standalone systems.
Old Oct 17, 2006 | 10:44 PM
The_Blur's Avatar
For the cams, yes.
For "tuning", nope.
You've got to love the ambiguity. At least their website gives a bunch of part numbers and companies to contact.
NJHK
Mar 24, 2025 05:57 PM
Cptnslo
Sep 24, 2015 09:32 AM
SS_2009_TC
Aug 28, 2015 09:15 PM
NJHK
Feb 15, 2014 12:29 PM
NJHK
May 31, 2011 04:53 PM
