CAN ANYONE ANSWER MY FREAKING QUESTION :confused:
Old Dec 2, 2009 | 10:14 AM
Jazer's Avatar
When you are sitting at idle, what does your boost gauge read?
Old Dec 2, 2009 | 10:15 AM
Maupin SS/SC's Avatar
Originally Posted by thesteed46
you had vacuum lines on a stock 2.2l.
where? we hooked up my boost gauge the lines that go from boost gauge to actuator like it said? ill hook it in somewhere else. the gauges were also not in when it was running fine so maybe thats it?
Old Dec 2, 2009 | 10:17 AM
thesteed46's Avatar
well i know you have at least one. the vacuum hose to your brake booster. if you have EGR you will have another
Old Dec 2, 2009 | 10:21 AM
wheres the brake booster is that by the intake manifold. and whats egr.
if you could possibly post a picture of where it is with something pointing to it thatd be great and i could undo the gauge and put a new tube in to the wastgate and bov, and try the car without the gauge.
Old Dec 2, 2009 | 10:26 AM
thesteed46's Avatar
the brake booster itself is on the driver's side right up against the firewall. the hose is about 3/4" thick and i cant remember where it hooks up to the engine.
EGR is exhaust gas recirculation. puts some of the exhaust back into the intake to burn it completly. Thnking back you most likely dont have it now, because you went turbo. not sure if it came stock on 2.2s or not
Old Dec 2, 2009 | 10:32 AM
so tapping into the line from the bypass valve to the wastegate could have caused a problem. I can replace that and leave the gauge unhooked to see if the car runs ok i guess.
Anybody know how to dicharge a capacitor? or what size the bolt for our battery connectors are. i need a new bolt for the neg?
i have a gauge without vac installed my buddy has one with vac that i had in there. it read 0
Last edited by Maupin SS/SC; Dec 2, 2009 at 10:32 AM. Reason: Automerged Doublepost
Old Dec 2, 2009 | 10:35 AM
thesteed46's Avatar
could be. im not familiar with turbos that much. i believe the bolt to loosen the cable is 10mm. as for the capacitor im not sure.
Old Dec 2, 2009 | 10:43 AM
Jazer's Avatar
When I did my turbo on my Cav I used a vacuum box. Found it to be easier to organize.
Like This:
Ahh I see... Your car is still registering vac, your gauge is just not reading it. I personally would install one that shows vac, that way you can see what it's doing.
I had my vac box Td off of my break booster on the box's main vac feed nipple. Boost gauge, boost controller, BOV were fed vac from the nipples on the front of the vac box.
My turbo, W/G & boost controller's map sensor, were fed off the nipple on the compressor side of the turbo.
Worked like a charm.
Old Dec 2, 2009 | 10:45 AM
elecblue06's Avatar
check to make sure your injectors are sealing in your head... it causes some funky issues if they don't..
Old Dec 2, 2009 | 10:46 AM
Jazer's Avatar
This is a good point, one of my injector o-rings split a month or so ago and the car was stumbling a bit, and was running real rough. However, it threw a CEL.
Old Dec 2, 2009 | 10:47 AM
  #36
i had a gauge with vac and i read 0!!!!!! and does anyone have picks of how the vac box looks hooked up. my bov ties into the recirc fittings and has a line to the wastegate nipple thats how the garrett kit runs. so what else would i do?
Old Dec 2, 2009 | 10:50 AM
  #37
copson20's Avatar
The vaccum line from the breakboster, is that hooked up to the intake manifold
Old Dec 2, 2009 | 10:57 AM
  #38
Jazer's Avatar
I have pics of how mine was set up at home, however Im at work and don't have those pictures here.
I want to say something is off with how your vac lines are set up. You might want to go over all your vac lines and make sure they are set up properly.
Old Dec 2, 2009 | 11:02 AM
  #39
elecblue06's Avatar
it wont always throw a cel there was a procharged 2.2 ion i did and it didnt throw a code for it .. and it was missing the injector seats lol
Old Dec 2, 2009 | 11:06 AM
  #40
Jazer's Avatar
Mine's a 2.0 as well.
Old Dec 2, 2009 | 11:18 AM
  #41
BlackCobalt707's Avatar
i just fixed this issue, took me months to find out the problem and a couple hundred dollars.
i dont know if anyone said it yet but a 2.2 has 2 vacuum lines. the brake booster and another that is a hard plastic line. facing your car, looks down at the top left of the throttle body is the line. if you follow it, it leads to a little black and white box that is being held onto the head and then on the opposite side is more plastic line.
Old Dec 2, 2009 | 11:21 AM
  #42
elecblue06's Avatar
hows your car running? you back in the NE?
Old Dec 2, 2009 | 11:22 AM
  #43
Jazer's Avatar
Evap solenoid
Old Dec 2, 2009 | 11:26 AM
  #44
elecblue - my car is idling, im waitin on a turbo gasket to show up so i can get rid of my exhaust leak. my laptop took a **** on my so i gotta send it to toshiba to get the hard drive replaced before i can tune it. but yea, im back in the states, i wanna go back to the desert tho lol.
jazer - i didnt know it was called that. i just know i can pull vacuum for it, i got my boost gauge and BOV hooked up to it
Old Dec 2, 2009 | 11:40 AM
  #45
i had an evap code when the car first got built and vince "fixed" that. could it still be the issue
Old Dec 2, 2009 | 12:19 PM
  #46
you never know, you just gotta keep diagnosing, word of advice, dont go to aamco. they suck ass.
Old Dec 2, 2009 | 01:16 PM
  #47
Maven's Avatar
Ok........ If the car ran fin before but you had a blown fuse and the car started acting like this when you replaced the fuse I think the first place you need to look is into whatever circuit/system that fuse is part of.....seems pretty obvious thats been neglected and could easily be the cause.
Old Dec 2, 2009 | 03:02 PM
  #48
06_ion2's Avatar
Originally Posted by copson20
How did u and vince come to that conclusion?
With the cams my car does the same thing not so much Any more cause I put a 2.4 TB on the car. 05-06 have no base running airflow chart so we can't tell the car where to keep the TB open at so the car has to hunt
Yeah i noticed this also with my s/c belt off it chokes itself with the stock tb and dies really easy.
Old Dec 2, 2009 | 04:05 PM
  #49
HunterKiller89's Avatar
has anyone suggested the basics yet? as in cleaning the TB?
dirty TB causing idling and opening/closing issues is ridiculously common on these cars.
nvm..OP claims its fixed
Old Dec 2, 2009 | 06:19 PM
  #50
how would i clean the tb is there special stuff?
Could you maybe post them when you get a chance
What would i look for to check i replaced them and some of the clips were off then i redid it and it still dies. would there be a little moistness on the tip (non sexual)? and does anywhere sell the injector clips thingys
Last edited by Maupin SS/SC; Dec 2, 2009 at 06:19 PM. Reason: Automerged Doublepost
