cataltic converter?
Old Mar 26, 2006 | 07:47 PM
razorhead89's Avatar
cataltic converter?
What exactly does this do...is it like a catback exhaust but just taking out a muffler and putting that thing in???
Old Mar 26, 2006 | 07:57 PM
boosted2.2's Avatar
you're no where close. a cat is an emissions device the is right after you exhaust manifold/header.
Old Mar 26, 2006 | 08:00 PM
roccityroller's Avatar
bingo, uses catalytic reactions to eliminate harmful emissions from you exhuast
Old Mar 27, 2006 | 03:10 AM
r@z0r's Avatar
Yep, so if you bought a Cat-back system, the stock Cat would still be in place in front of your exhaust system. I picked up a High-flow 2.5" Vibrant Cat last week.
Old Mar 28, 2006 | 02:37 PM
CivicKiller98's Avatar
from what i hear, there is a noticable difference between having a cat-back and putting in that high flow cat.
Old Mar 30, 2006 | 04:04 AM
NJHK's Avatar
Possibly but a little amount
By the way, the phrase "cat-back" means pretty much "from the catalytic converter and back"...that represents your piping, resonator (if you have one), and muffler.
Like said, the point of a catalytic converter is for emissions, yes. I will say that if you're going to upgrade your cat-back system (hence making it bigger), you should upgrade your catalytic converter to keep it the same diameter along with upgrading your header as well. While you will get some noticeable gains from just upgrading a cat-back system, you should get rid of the full restriction of your exhaust system. I know, sounds easier said than done when it comes to money wise but this is something you should achieve to do.
Good luck.
Old Mar 30, 2006 | 09:43 PM
r@z0r's Avatar
^^ I second that
Old Apr 3, 2006 | 04:08 PM
Roadrunner's Avatar
i'd like to see a dyno before and after of a high flow cat. seems only reasonable that it would work well with a cat-back and header.
Old Apr 3, 2006 | 05:43 PM
NJHK's Avatar
I mainly suggest people should get it to mearly keep the same diameter all through your exhaust and not have your stock catalytic converter be your choking or restricting point and decrease performance.
Old Apr 4, 2006 | 01:09 AM
CobaltCoupeCrazy's Avatar
Arrow
I have a thread posted concerning the possibility of having Random Technology manufacturing a direct bolt on high flow cat for our cars. I got my car up over my head today to take some pics for them, because they are interested and they asked me to send some pics. While under the car I also used a vernier caliper to measure the pipe diameter before and after the cat on my 2.2L. I had heard that the 2.2L had a much smaller inlet than the 2.0L. I measured the inlet to find it about 2.25" but the outlet was just under, that's right under 2.0". So a direct bolt on cat from the exhaust manifold to the catback of 2.5" with a high flow cat would be a great thing for us. It would also open up the sound of the Corsa catback's for us as well.
Scott
Old Apr 4, 2006 | 11:11 AM
Roadrunner's Avatar
Scott
i noticed that too, i even mentioned it on another forum, but got flamed to death. glad someone else caught it.
How to Guide
57
Oct 15, 2015 11:56 AM
Hill1513
Sep 21, 2015 07:18 AM
M-Dub
Feb 6, 2015 05:49 PM
TOGHeaders
Dec 20, 2005 09:17 PM
TOGHeaders
Sep 30, 2005 07:55 PM
