Changed Spark Plugs
Old Mar 19, 2006 | 09:20 PM
Hackas86's Avatar
Changed Spark Plugs
hey guys i changed my spark plugs over the weekend to a set of Autolite Cold Plugs. well now when i am driving down the road at a constant speed the car seems to jerk and my CEL light came back on. i have my spark plugs spaced just as much as the stock .042, anyone got some advice?
Old Mar 19, 2006 | 09:22 PM
Hackas86's Avatar
sry for double post comp was f'ing up
Old Mar 19, 2006 | 09:38 PM
CobaltCowboy's Avatar
just go to the other post and select the delect post option. cant' help with the plugs though sorry.
Old Mar 19, 2006 | 10:09 PM
RedBaseBolt's Avatar
Did you get the right heat range?
Did you get the same type of plugs even?
If not then you should.
Old Mar 20, 2006 | 02:14 AM
IonNinja's Avatar
you're running colder plugs? why? are you running nitrous or boosting?
Old Mar 20, 2006 | 08:55 AM
CleanNFun's Avatar
Yea, you don't need colder plugs. Thats just for teh s/c guys . Although I'm curious as to what brand the na's prefer?! So post to that!! As I'm going to look at mine, if they are bad I'm getting some new type.
Old Mar 20, 2006 | 09:42 AM
7Thirty's Avatar
What about the Bosch Platinum 4's... im thinking about getting those and changing out my wires but im not sure it it will be worth it or even work correctly.
Old Mar 20, 2006 | 10:03 AM
celicacobalt's Avatar
no need for a spark upgrade when car is not highly modified, go back to stock plugs
Old Mar 20, 2006 | 10:35 AM
GSoccer24's Avatar
probably not worth upgrading the plugs at this point, especially not to colder ones. if anything, i'd just throw in a set of Bosch Platinum +4's to smooth things out.
Old Mar 20, 2006 | 12:11 PM
hectanooga's Avatar
If you are thinking about changing wires on your Cobalt there is no need. The Ecotec doesn't have plug wires. The sparkplug caps and everything else are integrated into one unit. Its the black plastic part on top of the engine that says 2.2 Ecotec.
Old Mar 20, 2006 | 12:26 PM
take the cover off the unit and put a screw driver across 2 of the metal prongs sticking out and see what happens
Old Mar 20, 2006 | 02:31 PM
dnbguy86's Avatar
The ecotec uses a thing called compression sensetive coil modules or a combination of something like that, cant remember the exact name. But anywho, if you put something other than ac delco/ gm plugs in there, you have a greater risk for setting bogus codes, cause well honestly, most of the other plugs are low quality imitations.
Old Mar 20, 2006 | 04:02 PM
7Thirty's Avatar
Thanks for the advice... im getting things together now for my mods.. just picked up the car 2 days ago so... no time to do anything yet. Just ordered my intake and looking at the DC sports exhaust... When is a good point if any to change the plugs?
Old Mar 20, 2006 | 08:02 PM
06rallyss's Avatar
bosch plugs are junke everyone i no who has used them has had problems including me
Old Mar 20, 2006 | 08:31 PM
IonNinja's Avatar
as long as your stock plugs are good there is really no need to change them. there is no power increase from the plugs but you may notice better idle and a smoother start up. Again though, if your stock plugs are fine there is no reason to.
as for colder plugs you only need them when you are going to a first induction setup, they aren't going to hurt you in NA form.
Old Mar 20, 2006 | 08:43 PM
OneCOLDBIZL272's Avatar
first off you dont really need to change the spark plugs on the ls less your boosting or shooting nos are you doing ither of those two casue the spark plug really isnt going to do anything for you. but i dont know if the ls plug space is different from my ss sc but it stock gap it .35 and i gapped them at .28 and the rough idleing problems went away and no cel light ither your best bet is to go back to your stock plugs thou bro LATERS'
Old Mar 20, 2006 | 08:48 PM
d_backer1's Avatar
ROFLMAO your gonna get the poor guy bit
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
