clean engine bay
Old Dec 6, 2011 | 07:52 PM
killswitch1209's Avatar
clean engine bay
misc wire tuck, turbo tech racing intake manifold
before new struts rims and strut tower bar
and before ttr manifold and misc wire tuck
and after
Old Dec 6, 2011 | 07:58 PM
royce777's Avatar
looks good!!!
jonathan923's Avatar
very clean! nice work man. i love that manifold. freaking sleeper!!!
Old Dec 6, 2011 | 08:05 PM
MastaShaKe_88's Avatar
no before pics?
Old Dec 6, 2011 | 08:06 PM
ya
thanks just got the manifold on today in the snow lol it has way better throttle responce and in boost feels amazing ha ha
Old Dec 6, 2011 | 08:08 PM
same throttle body? no retune?
Old Dec 6, 2011 | 08:15 PM
ya same throttle body
i talked to vince directly from trifecta he said for me to log the car through a few gears and send it to him but otherwise it should be good and it idles fine and in boost it feels great just under boost feels like it could use a lil tweak
Old Dec 6, 2011 | 08:17 PM
BumbleBee's Avatar
Good **** man
Old Dec 6, 2011 | 08:25 PM
bspeed's Avatar
now put your stock 15's and hub caps on
Old Dec 6, 2011 | 08:37 PM
nice, and yep sounds about right. again nice work on a hella sleeper
Old Dec 6, 2011 | 08:54 PM
royce777's Avatar
whats the specs on setup?
Old Dec 6, 2011 | 09:14 PM
Its a cutsom turbo kit, im running a vulcan log style turbo manifold, a 50mm t3/t4 turbo, 39# injectors, trifecta tune, open downpipe, turbo tech racing intake manifold, custom universal piping kit, t bolt clamps, hks wastegate and bov, 8-10 psi boost
im thinking i made close to 300whp before the intake manifold so idk now
Old Dec 6, 2011 | 09:18 PM
drumrush's Avatar
300whp on stock internals is asking for trouble
Old Dec 6, 2011 | 09:25 PM
i know i drive it once a week if that its winter
im waiting untill summer till i build the bottom end, 8.5.1 je pistons, eagle h beam rods, cometic head gasket, arp head studs, new bearings and water pump, 80# injectors, and e85 going for 400whp in summer 2012
drumrush's Avatar
ok, i just didnt want to see you throw a rod or anything
Old Dec 6, 2011 | 09:27 PM
right i agree lol
Old Dec 6, 2011 | 09:31 PM
padlock's Avatar
id lower the boost a bit until you have internals installed.. one of the WI E85 2.2's that was running that same power level basically destroyed his block about 2 weeks ago. its simply not safe to run at
Old Dec 6, 2011 | 09:34 PM
sjc0013's Avatar
Window Licker
looks great man! I love that manifold
Old Dec 6, 2011 | 09:38 PM
really lame i did i was at 10-12npsi i lowered it to 8 psi for the winter and i don think im going back up to that much till its built too much work already invested
Old Dec 6, 2011 | 09:43 PM
TurboTechRacing's Avatar
Looks awesome in the black! (Intake manifold)
Old Dec 6, 2011 | 09:46 PM
ya i love it it makes the engine bay and i like the flat color u make one hell of a product throttle response is aewsome one question does the le4 throttle body fit the bolt pattern on the intake manifold??
Old Dec 6, 2011 | 09:51 PM
hhrfreek's Avatar
Yeah that manifold looks nice.
Old Dec 6, 2011 | 09:53 PM
PsychoCam's Avatar
hey man engine bay looks good. i see that u tucked some of the wires going across the main fram support rail. what else did u tuck?
also did u disconnect that air bag sensor in the crash bar? i was scared too lol
Old Dec 6, 2011 | 10:17 PM
ya i tucked those and put the injectors through the runners on the manifold and the main wire thats runs along the ac line tucked it under and the ones that go to the fuse box i still need to tuck some more but it looks good right i just put the other wire as far down under that i could with the slack it has!!!! ?? ooo and i removed the evap solidoid it takes up a lot of space on the right side of the cylinder head
Old Dec 6, 2011 | 10:49 PM
PsychoCam's Avatar
did u fully remove the evap solinoid system? how did u do that? doesn that go to the gas tank?
