cold air intake problem?
Old May 18, 2010 | 06:22 PM
kento19's Avatar
I added cold air intake to my 2005 ls automatic. Now my car jumps into gear very hard and it makes my car jolt. I also have a traction control warning lighting up. Is this because my mass air flow sensor is gone? if so, should i cut the senser out of the plastic of the air box and just plug it in. or should i set up the airbox again and put the ram straight into the airbox?
Old May 18, 2010 | 06:23 PM
reaper89's Avatar
ummmm you didnt put the MAF in the cai?
Old May 18, 2010 | 06:29 PM
kento19's Avatar
no. i have my filter right down by my passenger side fog light. the ram leads from there, right up where the silencer once was and right into my air intake system. i took the airbox off. how wrong am i?
Old May 18, 2010 | 08:51 PM
BLKLS's Avatar
The MAF read the amount of air entering your engine. Without it your car has NO IDEA how to meter fuel, sound like a custom intake, put the MAF back.
Old May 18, 2010 | 08:58 PM
redcobalt07's Avatar
wow you didn't put the maf back in? what a facepalm moment
Old May 19, 2010 | 04:27 AM
Dand89's Avatar
Umm...wow, definitely put your stock back on MAF is kinda needed a little bit.
Old May 19, 2010 | 04:56 AM
TexasTieaga's Avatar
I'm surprised you couldn't tell your car wasn't screaming, HEY!!! DO YOU THINK I SOUND FUNNY! There's a way to do the custom intake but it takes a little work and a little bit of skill. And destruction of your airbox if you don't have the MAF adapter piping which I think they have now but didn't when I made mine. But yeah, put your stock intake back in immediately if you have nothing to plug your MAF into. And make sure the MAF isn't dirty or you'll get a CEL. I mean don't even touch the metal part. They have cleaner at any auto parts store for pretty cheap. If you want the box mod (not recommended) they have a how to here I think, homemade (I have one and my car runs strong) there should be a how to here as well. I had an honor grad from UTI build mine. But you'll still have to hack apart your box.
Old May 19, 2010 | 07:59 PM
tru2nrtt777's Avatar
Wow, definately not good to not have a maf...
Old May 20, 2010 | 09:12 AM
rockstarbass1's Avatar
I thought this was a joke
Old May 20, 2010 | 12:14 PM
Blue_Balt's Avatar
What intake do you have OP?
If it doesn't have a slot for the MAF, put your stock back on or the car won't go anywhere.
Old May 20, 2010 | 01:25 PM
06G85's Avatar
That wasn't an intake you put on your car it was a supercharger.
Old May 20, 2010 | 02:32 PM
cobalt523's Avatar
hahahahaha if your flag looks like this you dont have to put the MAF in the intake
Old May 20, 2010 | 02:39 PM
importkiller's Avatar
This thread makes my head hurt!
Old May 22, 2010 | 05:14 AM
Btw... this guy isn't serious. Are you? I love the canuc and I know you guys are different but an engine is an engine
Old May 27, 2010 | 06:54 PM
kento19's Avatar
so i realize im an idiot for not putting the maf back. but can someone tell me whether or not i need the entire airbox set up. can i just cut the plastic out around the maf and plug it in? or do i need to put the cold air intake into the airbox? i dont want to because of the fact i had the ram modified to fit perfectly and know i will have to do figure something else out.
Old May 27, 2010 | 07:01 PM
Bl4des's Avatar
just go buy a intake so you dont mess up your car
and if you cant afford it dont mod your car
Old May 27, 2010 | 10:38 PM
SA420's Avatar
give em a break, he's a newfie
Old May 28, 2010 | 12:27 AM
cobalt523's Avatar
its all good, we all started out as noobs, FNG!!
Old May 28, 2010 | 06:50 PM
I hacked my airbox apart. If you do that make sure your rubber hose clamps are on tight and secure. But I do plan on buying a shortram in the future.
Old Jun 1, 2010 | 11:21 AM
1_quick_balt's Avatar
HAHAHAHAHA what a joke!
Old Jun 1, 2010 | 11:29 AM
F_Imports_09tc's Avatar
Put your airbox back to stock and save for a real intake. Unless you like breaking ****...
Old Jun 1, 2010 | 11:49 AM
Zero6LS's Avatar
put back ur stock intake box and save up for a good short ram. i love k&n the most. just buy watever one u like and read the directions and ur all good. its the best and safest way to go... good luck
Old Jun 3, 2010 | 11:51 AM
kento19's Avatar
why is everybody saying save for a real intake? i have a ram with a filter on the end of it((not sure of the name, probably not expensive). i bought it used off somebody, i had it modified to fit my car but i put it straight into my intake rather than into my airbox. Now i have another problem. The MAF is all set up but my car stalls when i let it idle most if the time, but only since i hooked up the MAF again. Somebody help me please.
Old Jun 3, 2010 | 11:55 AM
Bl4des's Avatar
take some photos of what you have done
Old Jun 3, 2010 | 01:04 PM
kento19's Avatar
i just edited my last post because my brother just said i had an aem intake which he is wrong about. im about to go take some pictures and ill post them!
one image shows the entire setup, the other just shows the ram going into the intake system. The arrow shows where my MAF goes. its tucked inside the rubber and the wire itself comes out and is tightened with the hose clamp. im not driving like this it was just my alternative method. my car wont even go like this. what else could i do?
