Coolant temp
Old Jul 12, 2008 | 12:51 PM
MP81's Avatar
Coolant temp
What's the typical coolant temp these cars run around with?
Old Jul 12, 2008 | 12:56 PM
ls1fbody's Avatar
Haz l33t wheelz.
180.
Spanky's Monkey's Avatar
i see 213 in hot ass you ain't going no where traffic and 194 when i'm crusin real easy like.
Old Jul 12, 2008 | 12:58 PM
MP81's Avatar
All right.
I think I hit around 213 while cruising around Woodward waiting for some of my friends. About 85 and humid.
I was worried because I'm used to my Camaro which rarely hits 160.
Old Jul 12, 2008 | 12:59 PM
ls1fbody's Avatar
Haz l33t wheelz.
my bad, this is the 2.2 area. i don't think it should be much different however.
damn i need to start looking at the Forum area.....
Old Jul 12, 2008 | 01:00 PM
D4u2s0t's Avatar
search "coolant temp" in the advanced search, and search the titles only. you'll find a shitload of answers.
basically anything under 230 is considered normal
my 2.2 ran an average of about 10 degrees hotter than the 2.0 does.
Old Jul 12, 2008 | 01:02 PM
ls1fbody's Avatar
Haz l33t wheelz.
ok then, 190 should be about right, which is what they're running.
Old Jul 12, 2008 | 01:16 PM
yep.
MP81's Avatar
Good, then everything is all ship-shape.
D4u2s0t's Avatar
yep. normally right around 190 or so.
Old Jul 12, 2008 | 01:20 PM
Blue_Balt's Avatar
Mine runs at 192-194(engine cover off) on the highway. In traffic it's gone as high as 210 and 204 when I took the engine cover off. I've seen it as low as 187.
Old Jul 12, 2008 | 01:25 PM
that's what i'm, getting give or take.
Old Jul 12, 2008 | 01:27 PM
MP81's Avatar
Yeah, it peaked at 213, but was more around 204-209
Old Jul 12, 2008 | 02:08 PM
D4u2s0t's Avatar
mine will go up to almost 220 sitting in a drivethrough or heavy traffic. the cooling system in our car needs airflow. and you dn't get that sitting still. once you start moving it should go down.
Old Jul 12, 2008 | 02:10 PM
originaladrian's Avatar
the cooling fan in the 2.2 does not come on till exactly 215F. so its normal to be around that, i see high temps everyday in S.FL. a trick is to put ur AC on or get a fan switch
Old Jul 12, 2008 | 04:10 PM
Jn2's Avatar
Jn2
190 on the highway...220max if i let it sit, than it will come down to 190 when the fan kicks, 190 if the a/c is one
Old Jul 12, 2008 | 04:59 PM
xxxxsh4d0wxxxx's Avatar
Mine generally runs around 190°F.
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
