Custom Intake
Old Mar 16, 2008 | 07:58 PM
tru2nrtt777's Avatar
Originally Posted by Red06LS
It sounds like u want to do someting like this. (?)
Minus the breather that is exactly it (I still want the crankcase pcv hooked to the intake). What size piping did you use? from the TB? does it vary diameter as it goes to the box?
Old Mar 16, 2008 | 08:03 PM
Jn2's Avatar
Jn2
yes the throttle body uses something around a 2.5ish, cuz my 3" tube is able to wrap around it, just use a coupler when u put on the intake, it shoudl tighten enought so it wont be a problem...the intake is 3" at the box, so stay 3" all the way
Old Mar 16, 2008 | 10:50 PM
alright, thanks bro.
Old Mar 18, 2008 | 12:26 AM
LS_RIDA28's Avatar
yea that set up is almost exactly what i wanna do except i wanna do cold air instead of ram air
Old Mar 18, 2008 | 12:30 AM
o3nisoaso3's Avatar
Originally Posted by tru2nrtt777
Does anyone know the O.D. of the TB inlet? I want to remove the big gay plastic chunk and make it more refined like an intake should be(and I like to see the mechanical stuff like fuel rail and TB.
I want it to look similar to this:
Eccept instead of it going into a conical filter, I want it to go to the stock airbox and remove the accordian which I have all bent up anyways from when I replace the filter....
i thot the coupler i had on right after i bough my car (custom intake) was 2.75" but that was almost 3 years ago so i could be mistaken
Old Mar 18, 2008 | 12:35 AM
LS_RIDA28's Avatar
i have a question how do the cobalts make 127 horsepower when GM advertised them to make 148?
Old Mar 18, 2008 | 12:45 AM
Jn2's Avatar
Jn2
whered the hell u get 127??? ive seen stock cobaltsmake between 112-120@wheels stock, i made 127.5wph, and 139wtrq modded...im looking at making more than that next time, as i have gotten a new header, new catback, new trq damper now, and i will have the dp from exhaust depot so im hoping to get a good 135 whp
Old Mar 18, 2008 | 10:05 AM
LS_RIDA28's Avatar
ok so why does chevy advirtise them at 148 horspower and 155ft/lbs of torque???
Old Mar 18, 2008 | 10:42 AM
07cobaltguy's Avatar
thats at the crank
Old Mar 18, 2008 | 03:25 PM
INDColtsFan18's Avatar
how do you remove the plastic engine cover. Whenever i turn the cap it won't move. Anyone know of a thread explaining it? Do i just twist that oil cap and yank it off?
Old Mar 18, 2008 | 03:43 PM
  #36
NS06G5's Avatar
well not yank, but give it a decient pull, it's not on there by much.
Old Mar 18, 2008 | 07:31 PM
  #37
Jn2's Avatar
Jn2
the cover has 2 tab like things that hold it, one in the upper left corner, and the other in the bottom right corner, the valve cover has a stem that foes into the cover to hold it but pull from the upper left and that shoudl come off, than pull from the bottom right and the same should happend..real easy, oh and take the oil cap completly off, dont just twist it, twist it and take it off
ps-148, 152 is what gm rated the 07+cobalt at the crank, 05-06 got rated 145, 155
Old Mar 18, 2008 | 08:04 PM
  #38
LS_RIDA28's Avatar
oh so which is the correct real horse power we're putting down, and what would bw the horsepower gain after i put a AEM cold air intake DC sports headers, and a DC sports cat-back exhaust???
Old Mar 18, 2008 | 08:20 PM
  #39
balt21's Avatar
the 112 to the wheels is about right. crank hp doesnt really matter in all honesty. with those mods you will maybe be at 130 if your lucky. i see you already have the k&n sri...you wont see that much more of a gain with the aem cai, maybe 1 or 2 hp at most.
Old Mar 18, 2008 | 08:29 PM
  #40
LS_RIDA28's Avatar
damn ok that sucks, what if i did a custom intake with a 3" inch diameter
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
