did the airbox mod and now i think i have a problem
Old Sep 4, 2006 | 09:35 PM
lscobalt4u2nv's Avatar
well i did the chop up the air lid and add a cone filter mod. but now my gas mileage has gone to ****. i did it a month or so ago. and i dunno what to do. and i have a problem with power distribution. sometimes the little bastard will run like a rapped ape. its an auto and if it idles to long or gets alil warm it runs like crap. and do i mean crap. it runs perfect at 189 and thats what it usually runs. or used to run, now that it runs at 190 its all gone to hell. is it the cat doing all this or what. i dunno??? this car is known for cutting some honda ass and now i am kinda worried of running anything.or unless i let my car sit with the engine off then run it straight from there. i dunno. guys please.... please....
Old Sep 4, 2006 | 09:43 PM
REIGN SS's Avatar
Original Hayden Fanatic
...if your that worried about it, turn the heat on in the cabin & roll the windows down
Old Sep 4, 2006 | 09:44 PM
g5mike's Avatar
Others with short rams an air box mods have complained of this lateley, while its nice to keep the filter out of the water the downside can be hot weather,causing extra heat under the hood affecting performance
Old Sep 4, 2006 | 09:45 PM
and something around my muffler smells like burnt ass and plastic? could it be my cat screwing me like this?
Old Sep 4, 2006 | 10:20 PM
jonnymerk's Avatar
What does burnt ass smell like
Old Sep 4, 2006 | 10:26 PM
HackAbuse's Avatar
Get a blow torch and find out
Old Sep 4, 2006 | 10:29 PM
rally's Avatar
MMMMM burnt ass....
Old Sep 4, 2006 | 10:48 PM
D4u2s0t's Avatar
1 degree is not making your car run like ****... these cars run fine at higher temps... over 200 it should still be running fine... i think around 230 fans kick on to bring the temp down...
i'm guessing your just fucked something up with the "hack the box mod"
Old Sep 4, 2006 | 10:50 PM
rally's Avatar
Probly messed up your MAF, and if you did then you'll learn to spend the money on an intake and not hack your box.
Old Sep 4, 2006 | 11:53 PM
savior's Avatar
make sure your filter is tightened - same thing happened to me!
Old Sep 5, 2006 | 12:13 AM
D4u2s0t's Avatar
how did it work out by the way?
Old Sep 5, 2006 | 12:27 AM
Switt23's Avatar
did you disconnect the battery for a while to let things reset themselves or does that even matter with this mod?
Old Sep 5, 2006 | 12:40 AM
OniMirage's Avatar
it would matter. your giving the car more breathing ability so forcing it to suck in more air while it isn't expecting it would be bad.
unplug the battery for like 10 minutes
plug it back in then turn the car on for like 10 minutes before reving the engine
give it a few revs after the 10 minutes it has been on
then turn off the car and turn it back on
then take it for a spin.
Old Sep 5, 2006 | 01:01 AM
savior's Avatar
when you disconnect the battery do you have to screw anything off?
Old Sep 5, 2006 | 01:12 AM
OniMirage's Avatar
im not sure on the other models but on the sc you unscrew a lil screw that holds the negative in place
Old Sep 5, 2006 | 01:15 AM
joeworkstoohard's Avatar
just look in the trunk, it's pretty self explainitory
Old Sep 5, 2006 | 10:54 AM
RedBaseBolt's Avatar
Make sure u installed the maf the right way around. If it's backwards the car will run funny. Also make sure you used a good quality filter like K&N. If you used a shitty $15 one then it could be the reason for your bad gas milage as the filters that are that cheap are not efficient and actually kill gas milage for sound.
Old Sep 5, 2006 | 10:57 AM
kissmySS's Avatar
Well that was some useful insight!.... Lol
Old Sep 5, 2006 | 12:41 PM
savior's Avatar
yeah really... so when disconnecting the battery, only do the negative terminal?
06blackg85ss's Avatar
yup.
Old Sep 5, 2006 | 03:47 PM
any help with how the maf sensor goes in. i am pretty sure that its in correct. i just want to be on the safe side. and i geuss i am going to pull the battery cable off, tighten the filter, and see if that helps. i thought if i fuc%ed up the maf then the car wouldnt run? that was my thoughts? but oh well. any more help would be appreciated.
Old Sep 5, 2006 | 03:49 PM
Brian MP5T's Avatar
There should be an arrow..
Old Sep 5, 2006 | 05:39 PM
nomoreavril's Avatar
do you have a picture? i had a custom cai on my focus, and after hydrolocking it , i moved on up to custom short ram, i took a saw to the tube with the maf, before the maf actually, and runs fine in hot weather. and i live in texas! i was at the track(110 degrees) and i used my cai, then switched to sri, and i ran the same times. i know cobalts engines are setup differently, and they dont sell sri's for focuses, so when i get a cobalt i'm just going to buy one.
and it is that crappy 20 dollar filter from autozone.
Old Sep 5, 2006 | 05:52 PM
savior's Avatar
your maf is in correctly, believe me
what filter did you use?
Old Sep 5, 2006 | 06:09 PM
e to the x's Avatar
This is just my opinion, but if don't know how to disconnect a battery perhaps you shouldn't be hacking up your airbox...
