Did i screw up my car!?
Old Nov 25, 2005 | 04:38 PM
FLCobalt's Avatar
I was racing a z24 cavilier and when i was shifting from 3rd to 4th i slipped into 2nd.
It grinded the clutch pretty bad. Any ways after that the way my exhaust sounded changed. The sound is similar to when i had a civic and the muffler got a small hole in it.
I checked for holes though and i couldnt find any.
But there is definately a change in the way my exhaust sounds.
FLCobalt's Avatar
any advice/ insight would be greatly appreciated.
Old Nov 25, 2005 | 04:54 PM
cvenom2122's Avatar
Thumbs up
prob spit the cat out bro! does it seem faster or just a louder note (exhaust)
Old Nov 25, 2005 | 05:32 PM
johnkb8's Avatar
FLCobalt what happen to the 3rd brake light cover you were supposed to send me
Old Nov 25, 2005 | 05:47 PM
FLCobalt's Avatar
its the same speed. I think the hinges got loose or something cause now its vibrating at high rpms.
Old Nov 25, 2005 | 05:53 PM
johnkb8's Avatar
thanks for the answer ...but good luck with the car
Old Nov 25, 2005 | 06:54 PM
FLCobalt's Avatar
i sent u a pm
Old Nov 25, 2005 | 11:15 PM
Clmbngfrk18's Avatar
yeah same here about the light cover
Old Nov 26, 2005 | 01:13 AM
97cavie24ls's Avatar
sounds more like you over reved the motor , and hurt it
Old Nov 26, 2005 | 11:08 AM
FLCobalt's Avatar
i hope i didnt. Wouldnt the CEL have came on if i did that though?
Old Nov 26, 2005 | 04:30 PM
forcedgminduction's Avatar
if it runs the same, my bet would be somewhere on the exhuast. jumping to that high of rpms probably put a lot of pressure through the exhuast and split it or blew out the gasket.
Old Nov 26, 2005 | 04:48 PM
wesmanw02's Avatar
Thats what I was going to say.
What exactly happened?? You say you were in 3rd, went to go to 4th, and hit 2nd instead. Did it actually engage 2nd gear, or did the grinding prevent you from shifting into it? What RPM were you at in 3rd when you shifted?? And if you did manage to get it into second, did you let out the clutch at all once it was engaged?? If so, the RPM's would have burried the tach well into the redline (depending where you were in 3rd when you shifted) and probably damaged your engine severely.
My friend did the same thing in his RSX, he was at the top of 3rd at 90MPH, went to go to 4th, and hit 2nd instead. Screwed up the head pretty bad, bent the valves, and damaged a couple pistons. Hopefully that didn't happen to yours though, it just depends how high the RPM's went after you dropped in from 3rd-2nd.
Good luck.
Old Nov 27, 2005 | 04:35 PM
FLCobalt's Avatar
the car drives almost exactly the same, it just sounds different. I also notice a loss in torque/horsepower.
Im thinking there is a small hole in the piping somewhere. Im not sure. But i took the car to like 100 last night and again it drives fine. But definately a difference in sound and a loss in pressure.
Im not sure if it actually went into 2nd it just grinded, but there was definately alot of pressure.
Im going to get it checked on monday!
Old Nov 27, 2005 | 05:07 PM
IonNinja's Avatar
if it still runs I would consider myself lucky
Old Nov 28, 2005 | 10:03 AM
CobaltBurst's Avatar
im not a great mechanic or anything, but i would check the plugs, maybe one or 2 fried? its easy to check and it could be causing mis-firing sounding like a holey exhaust?
Old Nov 28, 2005 | 10:48 AM
BLKSS's Avatar
Maybe the resonator got loose. I know mine made some noise then i got it replaced and fixed the problem. No more noise
Old Nov 28, 2005 | 08:33 PM
FLCobalt's Avatar
could be alot of things, going to gm dealer to get it looked at!
Old Nov 28, 2005 | 10:36 PM
Cobalt30's Avatar
so did u pop it back in gear and take the win in the race or did u just call it there and take the lose?
ryan
Old Nov 29, 2005 | 08:30 AM
FLCobalt's Avatar
no i still won =). but that hardly matters now because my friends 2001 civic with an intake and full catback can almost keep up with me now with my problem! thats why i need to get it fix.
Old Nov 29, 2005 | 08:46 AM
your sig says you have a "chip" is that the ebay special?
Old Nov 29, 2005 | 02:27 PM
FLCobalt's Avatar
yes its the useless ebay one. it didnt do anything for me i dont think but it seemed like my rev limiter went up like 2 to 300 rpms. cause it goes a little past red now.
Old Nov 29, 2005 | 04:49 PM
nice, seems like on mine it hits the limiter even before redline...
Old Nov 29, 2005 | 08:42 PM
FLCobalt's Avatar
i definately go past redline before it limits.
Old Dec 8, 2005 | 06:00 PM
Adirondack_Cobalt's Avatar
With my Cobalt, after I broke it in for about 2000 miles, I started to give a little RPM and the exhaust changed note, got a little raspier. And it got gutsy... more so than when i v bought it. My friends SS/SC did the same thing. I've overrevved my 2.2L a couple of times, never seemed to bother it none. Mostly, mine was at the top of 3rd gear, I wasn't really paying attention passing someone and had it cut out. I don't think the CEL will come on if you over rev it.. Mine never has any FWD Chevys I've owned. I HAVE HAD A PLUG WIRE COME OFF at about 5700RPM on my old 2.2L OHV engine... a whole bunch of warning lights came on... looked like a disco on my dash.
My friend Elroy had a 92 Cavalier Z24 with the 3.1L/5speed... racing a GTP Grand Prix one night, he went to shift from 5th into 4th at about 90 and missed... tagged second... the clutch only came out for a split second, but it was a enough. The car seemed to run ok until he got into the village and the stoplights; It had a weird miss at idle, not anything serious, just a weird pop... Bent a valve. Sure enough, he did. So, that was an excuse to piece together a 3.1L MPFI/3100SFI hybrid... What an animal!!!
I have missed (lack of a better term) on the way from 5th into 3rd passing someone, it gave a wicked grind, even with the clutch in. After rereading your post, I'm not sure what you did to this car.
Scott
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
