DIY Cold Air Intake
Old Nov 16, 2016 | 11:36 AM
Jlkm's Avatar
DIY Cold Air Intake
So, I am attempting to do a DIY Cold Air Intake for my 2.2L; and succeeded to a point. I bought a second air box top to have the place where the MAF sensor bolts too, and chopped/trimmed it. Then I added a coupler and some Spectre tube pieces (going as cheap as possible w/o using PVC, I have some dignity) and a K&N pod filter. Still needs some work but with some fiddling it fits. The problem comes that when started, the engine popped a P0300 random misfire code. Does the distance where the MAF sits inside affect the reading? Or is this a fruitless endeavor?
And before anyone says it, I live in Puerto Rico. Shipping to this island SUCKS *****. That's why I'm going the DIY route.
Old Nov 16, 2016 | 12:03 PM
Platinum_Injected's Avatar
any pics???
Old Nov 16, 2016 | 01:06 PM
If you change the size or position off the maf housing drastically, it needs to be retuned. Does it run better with the maf unplugged?
If i were you, i would build a tube that just runs to the stock airbox like zzp sells.
Old Nov 16, 2016 | 01:18 PM
Jlkm's Avatar
Originally Posted by Platinum_Injected
any pics???
The pics have to wait a bit but I'll try to take some
Old Nov 16, 2016 | 01:31 PM
Jlkm's Avatar
Didn't try with the unplugged MAF.
What I did was trim the tube where the MAF sits so that I could slip on a silicone coupler. Sort of like the airbox cut mod for N/A models. Then comes a 90 degree elbow to run it to the fender well.
Old Nov 16, 2016 | 10:05 PM
Jlkm's Avatar
I am proud of how it looks, just upset about the code. Also, yes I'm doing the other section as well.
