does anyone know how to make an o2 loop?
basically as teh title say's does anyone in here know how to make an o2 loop? cuz i know on hptuners it said it didnt support the 2.2 cobalt.. does anyone know about that too?
explain to me what u mean o2 loop, never heard of it...u mean closed or open loop? as far as HTP, they dotn work for 2.2's, if your a 07+than you can use Ls2edit, 05-06 can only be tuned by trifecta(or garret/hahn tune for their turbo kit)
p.s. u wanna run in open loop constantly unplug ur first o2 sensor, will throw a CEL but it will run in a open loop, besides that any other time it will be open is when the car is first turned on, after that it will switch over to closed
Closed loop = always runs at 14.7:1 AFR. Car switches to open loop after 5 seconds of WOT.
You have an 07, go with LS2Edit.
You can do a little o2 feedback tuning with a piggyback, but thats it. Basically trick the ECM into thinking the cars running leaner, so it adds fuel to get back to 14.7:1. Not very reliable though.
edit...didnt read...already posted lol
and about emissions, yes. all they do is plug in a code reader...you dont through codes you pass....if the codes arnt there they cant be thrown
Last edited by NWAE Cobalt; Dec 5, 2008 at 01:07 PM. Reason: Automerged Doublepost
The only way to get rid of a P0420 is to have a functioning emulator, or get a tune.
The only way to run open loop without setting DTCs is with a tune
get tuned
/thread
oh, and btw...you do know your car is pink right....
just sayin...cause...ummmm....ya
/thread
Last edited by NWAE Cobalt; Dec 6, 2008 at 04:13 PM. Reason: Automerged Doublepost
until you go wot for 5 or more seconds...then it kicks to open loop...its called power enrichment delay...its part of what vince tunes for
mine runs in open loop as well, makes EVERYTHING better on this car
, better idle, smoothing while cruising, better acceleration...its great lol
Yes he is right
They are also looking that all the ODB2 engine monitors are "ready" meaning that they have completed their diagnostics tests while you were driving. However if they do the tailpipe test your out of luck
I had stg.1 cams and I would have passed the test since I had all monitors ready after driving for about 1.5 months. The damn Evaporative Systems monitor takes forever to set
