Dual Exhaust?
Thanks for all the responses. I was just asking about this dual exhaust do to the dual magnaflow setup on the rksport car. I wasnt sure if it was a kit or not. I am quite aware that this would not be a big performance mod. this would only be for effect. If I wanted to hear true dual exhaust i would go out to the garage and fire up my 1967 Chevy C-10 with a built small block runnin through open long tube headers.
Originally Posted by 8cd03gro
what do you mean don't attempt it....true duals are impossible without two headers, you can't "attempt it"
Originally Posted by rallyyellow06
You can "attempt it" if you have the skills that are neccessary to create such a header to be able to attempt it. So yes its attemptable.
if you want it for looks, get a y pip at the rear axle... do not try to make a "real dual exhaust" because you can't make a real dual exhaust... this is a stupid conversation
Originally Posted by D4u2s0t
"attemptable??"
exactly...true duals can NOT come from a single header even if it is a 4-2. each exhaust has to come from a different cylinder bank, so once again...no it is not attemptable.
z28addiction
Sep 28, 2015 12:03 AM
