Ebay intake VS. GMPP intake
Old Nov 26, 2007 | 03:58 AM
  #76
NWAE Cobalt's Avatar
Ya, i reset the code with the battery twice, threw it again. went to shucks...and i got the same lean code as 06blackbalt....Could this be from a shitty filter?? Also, on my way home today (drove 60 miles back from a friends place) I noticed when i was coasting at freeway speed it was idling and bouncing around 500-1k rpms...isnt that way low and why is it bouncing. Could this be cause i am lean?? How do we fix this??
Old Nov 26, 2007 | 06:28 AM
  #77
Black07LS's Avatar
Try cleaning your MAF
Old Nov 26, 2007 | 07:56 AM
  #78
Preston's Avatar
Heh...went to buy one the other day.
Now there not on there.
awesome. hah
Old Nov 26, 2007 | 09:56 AM
  #79
Black07LS's Avatar
awesome. hah
Here it is http://cgi.ebay.com/ebaymotors/05-08...spagenameZWDVW
Old Nov 26, 2007 | 02:19 PM
  #80
I did clean the maf, threw it again afterwards.
Old Nov 26, 2007 | 02:41 PM
  #81
Jn2's Avatar
Jn2
i havnt thrown a code yet? are u still using the filter they gave u? i have the exact same ebay intake with a AEM dryflow and i havent gotten a code since i installed it, and its been well over a week now, no codes, no problems
Old Nov 26, 2007 | 02:47 PM
  #82
Ya, im still using that filter, I am going to replace it with the aem and see if it helps.
Old Nov 26, 2007 | 03:41 PM
  #83
Black07LS's Avatar
I'm using the filter that it came with also. Did you oil the filter? Ifso maybe you over oiled it.
Old Nov 26, 2007 | 04:18 PM
  #84
Did not come with oil...
Old Nov 26, 2007 | 06:29 PM
  #85
Beamer's Avatar
if its a paper filter oiling would be a no no, not sure what it comes w/ but the pic I saw was a paper filter I believe, definately getting that aem when it arrives.
Old Nov 26, 2007 | 09:00 PM
  #86
mine didnt come with a paper filter...see pics on pg 1...
Old Nov 27, 2007 | 03:40 AM
  #87
Sleepy06's Avatar
This is to funny, I put 30 miles on my car today and it threw a code so my check engine light is now on.Almost 2 years and never a code so it has something to do with putting this CAI on. One thing I do know,if its the same lean code as everyone else seem to get it has to be some type of vacum leak. I went through the same thing with my trans am I had and throwing a lean code,took months to track down and it ended up being a vacum leak in the intake after the MAF. With this cobalt CAI it has to be leaking around where that sensor goes into the pipe,I did check it and tighting everything down so we'll see.
Old Nov 27, 2007 | 03:44 AM
  #88
I may try putting some teflon tape around ALL the fittings...
Old Nov 27, 2007 | 05:30 AM
  #89
Black07LS's Avatar
I got mine used. it didn't come with the hose that goes to the valve cover. I installed the intake and drove it to AutoZone without a hose and still didn't get a code. I guess I'm lucky (knock on wood)
Old Nov 27, 2007 | 09:26 AM
  #90
moes's Avatar
I have a small question, and i know the answer on the chevy website but i really don't understand it... if i put an intake, headers, exhuast, rims, lights, and tint on my car will it completely void the warrenty or do they just mean my new parts aren't covered under the warrenty?
Old Nov 27, 2007 | 02:28 PM
  #91
your new parts arent covered, there is a new law that states that they have to proove beyond a reasonable doubt that your new part caused the part failure.
Old Nov 27, 2007 | 02:31 PM
  #92
M-Dub's Avatar
I would rather spend a little extra money for something that is a good brand than save 50 bucks on a piece of junk made by some little kid for 12 cents an hour!
Old Nov 27, 2007 | 02:38 PM
  #93
joeworkstoohard's Avatar
that's not a new law, but it's really there to protect the consumer where consumables are used.
in other words, it's to ensure that GM (or any car maker) doesn't void your warranty because you used a Fram as opposed to AC Delco oil filter. it's not in place to protect your right to modify a car.
Old Nov 27, 2007 | 03:02 PM
  #94
ya, but for me this is just until I get a turbo set up witha new intake, so i didnt want to spend 200+ for one that I only spent 20$ for mine...now all i need is a filter. I will do some checking to see if I can find out if there is a leak tonight.....pressure test time!!!
You are actually incorrect. This law was just recently changed so that any modd you add to your car (replacing an existing part in normal maintinance or customizing) has to be the proven cause of the failure...It was set in place so that those of us wishing to replace the rims on our car dont have to deal with the dealer voiding the warranty on our stereo or something of the like. You can customize what you want, and that specific part will not be under warranty, but in order to void the warranty somewhere else, they must prove it was your new part's fault.
Last edited by NWAE Cobalt; Nov 27, 2007 at 03:02 PM. Reason: Automerged Doublepost
Old Nov 27, 2007 | 03:06 PM
  #95
right, but as i recall, it talks about replacement... so rims, speakers, radios, batteries, sure.
but if you installd a part that wasn't even close, it's not going to help.
i'm just saying that you shouldn't modify if you're not willing to take ANY risk
Old Nov 27, 2007 | 08:53 PM
  #96
Preston's Avatar
Heh..just take the part off before you go to the dealer..if its a intake.
Im PRETTY sure if you buy everything from GMPP AND have a dealer install it (GM specified) it wont void your warranty..or atleast thats what the mechanic told me when they were putting my wing on.
Old Nov 28, 2007 | 03:16 AM
  #97
avenger09123's Avatar
I installed the ebay CAI with no problems about 1,000 miles ago, it did me pretty good. those pipe clamps are pieces of ****, I had to put mine own on. I tightened them down really really well, and the MAF is in there without the seal, I have no CEL yet. I used the air filter they sent me too, which was a cotton-dry flow. Remember too make sure your MAF sensor is installed the right direction. If it's dirty, clean it off with a super small shot of brake cleaner. But hey, I'm lucky I guess. I talked to the parts guy here at my chevy dealership - he said if GM installs GMPP parts, they're designed to last as long as the car does, and won't void your warranty (lord knows GM mech don't ever make mistakes do they).
Sorry I'm a little bitter - one gm tech said getting warranty work was like playing a slot machine
and the other one took 6 days to day a "2" day job, and ended up putting my tranny back together wrong anyways.
Old Nov 28, 2007 | 08:58 AM
  #98
moes's Avatar
thanks for the help =]
Old Nov 28, 2007 | 03:31 PM
  #99
I tried flopping my maf around, the screw holes didnt line up, so thats not it. I cleaned it, not sure if that helps yet haha. I am going to replace the filter and tighten ALL the fittings on it. Hopefully that helps!!
Just ordered the AEM online,...will see it in a few days...will let you all know if this helps. Since i have to take the head light apart to get to it anyways, ill do a pressure test then and tell you all the results!!
Last edited by NWAE Cobalt; Nov 28, 2007 at 03:31 PM. Reason: Automerged Doublepost
Old Nov 28, 2007 | 04:50 PM
  #100
Jn2's Avatar
Jn2
good luck, once more i strongly recoment the ebay ntake with a AEm filter, have gone the custom route, i didnt lke it, i bought a GMPP, still no good, now with the ebay one, its alot better, especially in the cold, only thing is that like all other intake, when it rains, the water drop in from above from when i rolls of the headlight and hood, ait drips down thru the crack, but nothn to worry about, the filter would have to be submerged to really worry about anything
