Engine electronics,fuel air management
Old Oct 28, 2007 | 01:01 PM
cobaltturbo's Avatar
what do i need , or should i have for a pretty much full built 2.2 Ecotec , i have most of the parts , for the motor build , just need to figure out the electronics
Thank you for any of your help
The build is for 500-800hp build
Old Oct 28, 2007 | 01:04 PM
halfj99's Avatar
huh? what are you trying to do?
Old Oct 28, 2007 | 03:42 PM
FacelessKhaos's Avatar
what year model is your car?
Old Oct 28, 2007 | 06:00 PM
Sw4y1313's Avatar
You want a 600hp built car replace the pistons, rods, and get ARP Headstuds. The crank is 600hp rated and the sleeves are too. If you want 1000hp rated you gotta replace the crank($700ish) and sleeves(another $700ish).
Old Oct 28, 2007 | 06:21 PM
cobalt9123's Avatar
trying to figure out the electronics? Ecu? transmission? Standalone? need to be more specific...
Old Oct 28, 2007 | 09:21 PM
IonNinja's Avatar
for those power levels there is no question that you're running full standalone
Old Oct 29, 2007 | 07:57 AM
the car is a 2006 Cobalt ls 5sp, and it is stand alone i am looking for , but it is what one , and what else i need with it ! as well as looking for the cost of them , The motor is built with sleeved block, custom wisco pistons over size , eagle rods, and crank , GM ajustable cam gears,cams, and natural balance shafts, full valve train to mach ,
Old Oct 29, 2007 | 12:04 PM
IonNinja's Avatar
well there are none specifically made for the Cobalt so which one you choose really is going to be up to you.
the cheapest one is going to be Megasquirt but is going to require you to do all the wiring.
http://www.diyautotune.com/catalog/p...622740aa824f68
Old Oct 29, 2007 | 06:59 PM
thank you i kinda like that is it swichable on the fly if you have a lap top set up to it , and do you need any thing else with that !
Old Oct 30, 2007 | 12:54 PM
Sw4y1313's Avatar
i know something that is just as cheap as MS and does all the same things, but easier! Perfect Power's XMS-L stand alone. It already works with all of GM's sensors, including the crank sensor. Its built around the 60-2(58X) setup. Its made specifically for 4cyl wasted spark cars. It can be hooked up just like MS to control just fuel and timing. It also has a electronic boost controller built in, with aux inputs for nitrous control. You can run narrow-band closed loop as well. If you go with the XMS stand alone it has the ability to run wideband closed loop as well.
Old Oct 30, 2007 | 02:40 PM
RollermanDan's Avatar
If you want to go top notch, you'd have to get the MSD Digital Programmable 7 (4cyl) and F.A.S.T. XFI. That's what I'll be running.
Old Oct 31, 2007 | 10:59 PM
MSD it is thank you all i am all use to V8 carb cars , this is the frist front wheel drive i will have ever diven and build , so thank you all ,
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
