engine mounts
engine mounts
my brothers 2005 chevy cobalt 2.2 with a garret turbo pushing around 10psi, has estimated 275whp+ but the engine mounts are oem, what is a great site that has upgraded ones and has the best bang for the buck? let me know guys/girls, thanks
not sure on new mounts but a few friends of mine have poly filled there stock ones to help out, idk if that helps you any but i thought i would throw that in there, im about to do mine to help with the motor twisting
Garrett kit Ive seen/heard of 2 05 2.2 cobalts with this... did he build this himself or purchase it? Im trying to locate my old 2.2 with the garrett kit
best bang for the buck is a $5 tube of polyurethane to fill in the gaps. Will make a huge difference... and can't beat the price.
full poly mounts will make your interior shake like a dump truck... something to keep in mind.
u clearly have never had fully poly mounts before its more noise then shaking, and its a 2.2 no way it will ever shake like a dump truck unless the motor is about to **** out
the pundits here are all special olympians.
of course, I wouldnt know what my experience has been with poly mounts... you would know that.
... everyday, it's a full scoop of facepalm in here.
Don't fill the stock mounts with poly. It is a big waste of your time, it will come apart and hop will come back in a few days.
If hop is a problem or **** feels like its banging around I suggest TTR poly trans and the TTR upper mount. It will help a lot! Vibes are minimal(noticeable, but not bad in anyway) even with poly in this car...This is a smooth engine.
Powell mounts are another option. They work great too and vibes are close to stock, almost unnoticeable, but price is a bit higher.
back to the member that does a "Honda ricer" $5 poly job fill.
patooyee
Oct 1, 2015 01:07 PM
