Engine Tapping Noise?
Old Jan 14, 2011 | 07:25 PM
Foximus's Avatar
So, my 2006 has 117,500 miles on her. Ive started to hear a tapping noise from the engine while driving. Its been too cold / I havent had time to look at it yet, but I'm assuming timing chain or Lifters (coming from the VW world, you get used to that) Anyone else have this problem, offer suggestions, things to look at? How badly Ima get raped to make it go away?
Old Jan 14, 2011 | 07:29 PM
Turbalt2010's Avatar
sub'd for answers as well. im curious
Old Jan 14, 2011 | 10:44 PM
jmesl8er's Avatar
could be an exhaust manifold leak, that sounds like a light tapping noise, check you tube, theres a video on how to check for exhaust leaks
Old Jan 14, 2011 | 11:40 PM
Foximus's Avatar
Exhaust system hasnt been touched since August.
Its loud... gonna try and limp to a GM dealership tomorrow to have it looked at. So far thoughts seem to be a timing chain / tensioner or maybe rod knock :-\
Just sucks.
Old Jan 15, 2011 | 12:01 PM
Leafydialupking's Avatar
Open the hood and poke around with your biggest screw driver (or mechanics stethoscope). That'll make it pretty clear. But if you used a fram oil filter I'm willing to bet money that it collapsed and is restricting oil flow causing your lifters to tick. Just use the damn ac delco filter from the dealer, its cheaper than the fram anyways.
Old Jan 15, 2011 | 12:19 PM
ecot3c inside's Avatar
I doubt it's a major thing like a spun rod or anything. usually a ticking or tapping (fast pace) is up top, like a rocker arm, lifter tick.
Old Jan 15, 2011 | 12:30 PM
Foximus's Avatar
I use AC Delco or the purolator filters. never had a problem. gonna listen to it again when someone else is here
Old Jan 15, 2011 | 12:58 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Cam Chain Tensioner
[/thread]
Old Jan 15, 2011 | 06:40 PM
joshc.'s Avatar
Does it change with RPM? My gues would be the timing chain tensioner.
Old Jan 15, 2011 | 07:13 PM
kxrida2000's Avatar
ya man most likely timing chain tensioner
Old Jan 15, 2011 | 07:24 PM
C_A_D88's Avatar
would that be covered under the drive train warretny?
Old Jan 15, 2011 | 07:55 PM
Its part of the Drivetrain, isn't it?
Old Jan 15, 2011 | 07:58 PM
Foximus's Avatar
When your over 100,000 you dont have a warranty.
And it ate a rod bearing. I'm pulling the engine and swapping to my backup tomorrow.
Old Jan 15, 2011 | 08:01 PM
Oh damn. I wonder how that happened. You slacking on you oil changes or not using good oil?
My rod bearings looked brand new when I popped the pistons out at 95k miles.
Old Jan 15, 2011 | 08:08 PM
Foximus's Avatar
No. I change oil (castrol GTX) and Filter (ACDelco, Wix, or Purolater) every 3-4k. I take damn good care of my stuff. I dont really know what went, I drive the car, but I dont hammer on her.
Old Jan 15, 2011 | 08:15 PM
ransomfoyou's Avatar
i have the same problem i think. but every time i take it to gm they beat around the bush and never fix my problem
Old Jan 15, 2011 | 08:24 PM
Foximus's Avatar
This went from no noise, to oh sweet jesus ***** flying around in 4 days. heh
Old Jan 15, 2011 | 08:28 PM
PsychoCam's Avatar
I will be there around 9 chris.
Old Jan 15, 2011 | 08:41 PM
Foximus's Avatar
Thank you. And no flipflops!
Old Jan 16, 2011 | 11:59 PM
joshc.'s Avatar
Same thing happened to mine about 3 weeks ago. I noticed oil consumption 2 weeks before it happened, watched it like a hawk but it still took one out. I also found the intial cause, a chunk missing out of the ringland.
Old Jan 17, 2011 | 12:50 AM
PsychoCam's Avatar
full engine swap was done today! She runs again!
Old Jan 17, 2011 | 12:43 PM
kxrida2000's Avatar
nice ill be at world of wheels saturday ill be sure to stop by
Old Jan 17, 2011 | 01:08 PM
Foximus's Avatar
As soon as I know whats going on with WoW i'll let you know man!
I'm thinking a 12:1 compression, maybe stroked NA motor may be built out of my original engine....
Old Jan 17, 2011 | 03:44 PM
06_cobalt's Avatar
Sounds like a nice plan.
Old Jan 22, 2011 | 11:31 PM
Sumasianluv's Avatar
Probably the timing chain tensioner, theirs an updated one made by GM
