Exaust components
Old Apr 28, 2006 | 09:15 AM
NyCobalt88's Avatar
Exaust components
im planning on building my own exaust, but i want to but a magnaflow resignator, catalytic converter (spelling)?? and a muffler, i was wondering if some one bought any of this shiznit for there 2.2 ls and can tell me what pruduct numbers u guys put onto ur cars. thanks alot
Old Apr 28, 2006 | 09:57 AM
7Thirty's Avatar
Honestly by the time you purchase everthing and go thru the labor of putting it on u will have probably spent the same as getting an aftermarket exhaust and my not see the gains that the aftermarket would produce. Get the Resonator... High flow cat and then maybe a DC sports muffler and ride out... but i would price everthing out and weigh out both options.
Old Apr 28, 2006 | 10:58 AM
CivicKiller98's Avatar
www.gravanatuning.com has a magnaflow cat and a couple mufflers to choose from. talk to a shop and ask how much it would be to get a custom exhaust, it usually ends up being cheaper than a cat-back, but like stated above, you have no idea of gains (or in some cases, losses).
you dont want to get a muffler with a tip large enough to put your hand inside, this causes people like me to point and laugh at your car.
good luck, post pics when you are done.
Old Apr 29, 2006 | 03:07 AM
NJHK's Avatar
I'm sorry but that's incorrect.
Just because a companies name is on a product, doesn't mean it will yield more power than other companies. The reason you gain power from upgrading your exhaust is because of:
1. Better Bends (less restrictive)
2. Bigger in diameter (able to flow more exhaust)
As long as he takes his car to a reputable shop that's local to him that can do mendrel or compression bends properly, he should be 100% fine and gain the same amount of power as anyone with an "pre-made" exhaust setup.
As far as pricing goes...there have been plenty of people who have spent much less on a custom exhaust setup (parts and labor) and come out spending less money comapred to just buying a pre-made exhaust system from some company. It honestly all varies.
To the orginal poster...
As long as you buy parts from reputable companies (Magnaflow is a good idea ) and don't go over 2 1/4" diameter (honestly, 2 1/2" is too big), you should be fine. Good luck.
Old Apr 29, 2006 | 02:46 PM
NyCobalt88's Avatar
thanks alot njhk, i actually planned on doing exactly what u said, there is a garage that did a dual exaust for my dads 2500 series pickup, and they did an awesome job.. so when i get some money (i just ordered springs) im gonna do that
Old Apr 29, 2006 | 03:22 PM
NJHK's Avatar
You're welcome and good luck.
Old May 1, 2006 | 10:24 AM
7Thirty's Avatar
LOL i didnt say he WOULDNT lol i said he MAY not.. what u said is correct... which was the point i was getting at. The shop has to know what they are doing.. and also not be chargin u out the azz for labor. Some shops(once u mention something custom) start gettin ridiculous with the labor... Thats why i was saying.. price it out... and see what option seems to be the better deal. Research the spot your going to also.
NyCobalt88
Hope the custom set up works well for you!! I did it on my blazer and it worked wonderfully.. Best Wishes
Old May 1, 2006 | 01:03 PM
Roadrunner's Avatar
i had 2 1/4 on my cav when it was N/A, then bumped it up to 2 1/2 after i got some boost, then left it at 2 1/2 after the turbo was off, and:
1. the 2 1/2 sounded better (deeper tone)
2. i had about 1 hp MORE with the 2 1/2
2 1/2 in your experience may have given you some bad results, but it gave me some great results and i was happier with it than my 2 1/4.
here is a good link, that chart on that page hasnt failed me yet
http://www.magnaflow.com/07techtips/faq/question10.asp
Old May 1, 2006 | 04:09 PM
ssritz's Avatar
you are correct
OrangeCoba
Oct 1, 2015 10:00 PM
medic710
Sep 6, 2015 08:53 PM
Turbo6
Aug 27, 2015 08:37 PM
Xenozx
Dec 29, 2005 02:02 AM
JAESS
Oct 30, 2005 11:29 AM
