fuel cut-off
Old May 1, 2006 | 01:29 AM
CobaltCowboy's Avatar
fuel cut-off
what controls the fuel cut-off and can it be adjusted? i was out testing the limits after work when i hit roughly 125mph give or take and the fuel cut-off kicked in and my rpm dropped to ****, to about 4000. it felt like i hit something. i'm confident this car can go much, much faster then this, so how do you do it?
Old May 1, 2006 | 01:45 AM
joedashow's Avatar
I don't know, maybe the speed's governed on the base model. Not sure though, just a possibility.
Old May 1, 2006 | 01:56 AM
Cobalt_Supercharged's Avatar
The 2.4 can have the cut off raised with the tuning from Vector, and I think Tune Time Performance. Might want to talk to them and see if the 2.2 PCM is cracked yet.
I would try Tune Time first since they are a supporting vendor and were talking about tuning the 2.2.
Old May 1, 2006 | 01:57 AM
Clmbngfrk18's Avatar
no way around it right now but stock tires are only rated to 130 so you shoudltn be doing over that speed do you wanna find out what happens when you blow out a tire at 130 plus look at is this way at least you got to 125 some of them only do 108
Old May 1, 2006 | 01:58 AM
CivicKiller98's Avatar
its in the ECU, the only way to really change it is to get some tuning software which isnt available for the 2.2 cobalts yet.
it is usually based on the rating of your tires so if you are going to bump up the limiter when you can, i would give some thought to upgrading the tires too.
Old May 1, 2006 | 09:40 AM
thanks for the help guys! new tires are a coming.
Old May 1, 2006 | 09:47 AM
dnbguy86's Avatar
Actually if you were to throw on the factory rims that come on he LTZ, the 16in wheels, GM has an update to correct the speedo, up the top speed, and a few other things, i tried to do this at my dealership, but couldnt find any factory 16in rims.
Old May 1, 2006 | 09:54 AM
patathSS's Avatar
Sounds like you found the limit...125mph LOL
Old May 1, 2006 | 05:01 PM
tiny's Avatar
if you have the H rated tires, itll only do 120
you could, throw in a VSS cutoff switch, that way you could get around the limit
Old May 1, 2006 | 10:09 PM
i thought the vss mod didnt work on the cobalts
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
