exedy and fidanza
As far as I have read no it won't. The only flywheel that will fit with an exedy clutch is an exedy flywheel. By the way I must say I am impressed with your 1/4 mile times. I am working on finishing up my 2.2 and taking it to the track and see if I can hit 14's along with you and NWAE.
If the fidanza is just like the stock flywheel, but lighter, then there shouldn't be any fitment issues. Find out if they have the same clutch bolt pattern on it and if so, your good to go.
we feel alone up there
I know before you beat out NWAE I told him I was coming for his spot and he basically said the same thing that it was lonely
As soon as I get a full exhaust setup and the stage clutch + flywheel I plan on running it and see what she does then I m going from there. Oh and your welcome
is it still stock at 6500?
Is that with the current mods I have in my sig or are you including the stg 1 clutch and flywheel I plan on getting sometime soon? Also if you don't mind what would you predict with all those things plus h/dp/e since those are the last things available for a NA L61 except cams and internals.
it work. a french canadian put one in is 2.4
http://cobaltssquebec.forumup.ca/vie...cobaltssquebec
thorin mods:
new clutch bearing
flywheel fidanza
clutch exedy stage 1
it is in french but who care......
thorin mods:
new clutch bearing
flywheel fidanza
NGASales
17
Jan 19, 2007 06:27 PM
vandy0419
Jul 12, 2006 07:54 PM
