Exhaust Headers...
Old Nov 21, 2007 | 09:28 AM
slindborg's Avatar
Exhaust Headers...
Guys an exhaust header (a poor make one) costs MINIMUM of $1000 here ranging to $2000 lol.
Ive seen the OBX stainless items in ebay and other places. Thing is I'm not 100% sure what angle the manifold sits.
If you can visualise with me.
The manifold comes out of the head, goes through 90 degrees and goes into a collector and then the down pipe hooks up and carries on parralel to the block till it gets to the cat blah blah.
The OBX header http://cgi.ebay.com/ebaymotors/OBX-E...spagenameZWDVW
seems to NOT go through 90 degrees.... Am I right or wrong?
Any pics of a header mounted to an engine out of the car?
Old Nov 21, 2007 | 09:30 AM
lsjwannabe's Avatar
that looks like a pacesetter header you would need a modified downpipe to fit that. why not just get a ss/sc manifold or the gm one
redlineblueline's Avatar
i was about to say what are you smoking with that price but your across the pond
Old Nov 21, 2007 | 09:56 AM
IonNinja's Avatar
more than likely just a generic picture
Old Nov 21, 2007 | 10:32 AM
slindborg's Avatar
Just for the record, the engine and header arent in a cobalt... meaning modifications to any part acquired... unless there is a short 4 branch manifold that fits exactly where the stock one does....
Any one got a picture of a cobalt manifold fitted then?
Old Nov 21, 2007 | 10:43 AM
i know hahn and cobalt addiction have ones that fit directly into the stock space
Old Nov 21, 2007 | 11:08 AM
slindborg's Avatar
all the picture seem to show the headers NOT going through a full 90 degrees and they exit sort of horizontally.... booooooo.
Might get a cheap mild steel manifold to see exactly what the difference is though
http://cgi.ebay.co.uk/Vauxhall-VX220...QQcmdZViewItem
thats the stock one I have.... you can see it does a 90degee turn and exits straight down.
Old Nov 21, 2007 | 11:11 AM
ItalianJoe1's Avatar
Yeah, our stock manifolds only have about a 50 degree turn in them, not enough for what you are looking for. Get a flange from Crate Engine Depot and have one custom made, it will be easier than trying to modify an existing header.
Old Nov 21, 2007 | 11:35 AM
slindborg's Avatar
do the pacer manifolds have a similarly shallow angle on them to meet with the cat pipe?
getting a manifold custom made will cost big cash too I need to investigate more.
Old Nov 21, 2007 | 11:38 AM
we need a bit of info from you...is this in the roadster looking car you posted before..is it front or rear engine, FWD or RWD?
Old Nov 21, 2007 | 11:46 AM
slindborg's Avatar
yeah its the roadster in the garage..
Mid engine Rear Drive (ok rear engine as technically the centre line of the engine is infront of the main centre line of the gearbox lol)
The "trunk" is fouled when a Tsudo Weapon R ram horn style manifold is fitted.
the angle is a bit naff on the pics but this http://www.2bular.com/news.htm is the system where the stock header bolts too (top of the flexi)and does a 90degree turn to hit the head.
I dont mind having to make a pipe to include the cat to then connect up at the U bend before the silencer.
Old Nov 21, 2007 | 11:50 AM
i would get a shorty header from hahn or Cobalt addiction as it bolts to the stock exhaust system in the same space the stock manifold sits in
Old Nov 21, 2007 | 11:54 AM
slindborg's Avatar
The hahn shorty on their site only appeared to go through the 50degrees.. unless I was looking at the wrong part.
you have a cast iron manifold on there right now correct?
Old Nov 21, 2007 | 11:57 AM
slindborg's Avatar
correct. (I may be well off the mark with it being a 90degree bend lol. infact I maybe utterly wrong ffs. The part I have on at the moment is numbered 24438033 Kat number 850059 http://www.speedsterclub.nl/biblioth...old/index.html)
Old Nov 21, 2007 | 11:58 AM
under the heat shield there is where the cast iron one would sit..you can get the rough angle off of it
shorty one that fits in the same spot
Old Nov 21, 2007 | 12:48 PM
IonNinja's Avatar
the Pacesetter follows the same angle as the shorty, it is just longer.
Old Nov 21, 2007 | 03:41 PM
slindborg's Avatar
looks like its a mod to a mild steel pacesetter to see if its any good then...
Old Nov 25, 2007 | 09:13 PM
djblass's Avatar
sorry their have some questions regarding a 2.2 if you get the zzp header is their any modification needed for it to fit a 2.2 and is it the best one out their ? is the zzp downpipe better than the cobalt-addiction downpipe ?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
