Exhaust Install?
Exhaust Install?
As you may or may not know...I have a stainless steel borla cat-back waiting to be installed. Is there anyway I can install this with just a jack....Can the stock exhaust be taken off with out being damaged, and what tools will be required?
so you mean to say that you ditched the exhaust you got from mandrel bent systems to get a full borla catback? or are you trying to claim that the mandrel bent exhaust system you have with a BORLA muffler is an actual Borla cat back?
cause now i'm confused.
With just a jack.... up yea... but i wouldnt recomend it lol
get some jackstands and you will be all set.
when i did mine i had to cut my old one so i could get it out but if you had a hoist then you wouldnt need to cut it.
my new 3" one that my buddy made me is all one peice and he did it using a jack and jackstands.
sorry guys yes it is the mandrel bent with borla muffler just trying to conserve using that whole phrase just to represent the exhaust lmao, but my girl has like 5 jackstands and I have a really good jack so I was hoping maybe just cut the stock exhaust in half and put the new one on piece at a time. will it work? btw trying this tomo so if you have any advice I would most highly appreciate any input
go buy a $5 hacksaw from autozone and cut right before the rear torsion beam, and than u can do it all in your garage with hand tools, a jackm, jack stands, and some elbox grease, i do all exhaust install in my garage :p everything from the header to the tip...
lol sorry jn but I dont have the knowledge you do what beam are you talking about, like where is it located? everything else I have hacksaw,saw-zaw elbow grease
) just dont know where that beam is?
do NOT just use the jack, unless you want to die.
the torsion beam is what most people incorrectly call the rear axle. You'll see the big metal thing with roudn holes that the exhaust goes over before the muffler. There's nothing tricky about installing and exhaust. make the cut, take off the muffler, unbolt the 2 bolts, and the rest comes off. put the new one on, tighten it up, done.
thank you very much for the informative pics... I think I have a pretty good idea of what to cut...wish me luck lol
[IMG]
[/IMG] how does everything look are the hangers right...jn and i dont know what came in the bag next to it...looks like maybe new screws,boltss,clamps
[IMG]
Last edited by StrongIslandBalter; Apr 8, 2009 at 02:05 PM. Reason: Automerged Doublepost
that looks good, the baggie probably has the clamps u need to tighten the piping together where they go into the next pipe...looks good man, now go put it on, i have experience with their exhaust, and it fit pretty damn good
ps ill be buying that same exhaust soon hahahha, i need one, but im getting the regualr steel one, and im just painting it to prevent rust
okay one more thing the gasket that came with its gonna go at the end correct and connects to the downpipe? seconndly looks like two clamps sos do you think their gonna connect where the pieces meet (3 pieces go together leaving two movable slots) the clmaps will fix that
exactly... it looks like that piece would stick into the downpipe... which is not only ass backwards, but it looks like it will add some restriction which defeats the point.
well i also didnt push as hard as i could to put the piping in eachother i just wanted to set it up to see if the hangers are right
thanks jn
) do you mind deciphering what they are talking about with the downpipe and restriction?
thanks jn
Last edited by StrongIslandBalter; Apr 8, 2009 at 02:54 PM. Reason: Automerged Doublepost
that wont be a issue with the exhaust dont worry about it, they cant see that the pipe on the ur exhaust is flared out to prevent any leaks, flared out, exhaust will work fine, and will bolt up to w/e dp u have now
I have this exhasut too, except with the magnaflow muffler, sounds great.
