Exhaust Manifold
Old Aug 12, 2007 | 09:17 PM
ddrfreak's Avatar
Lightbulb Exhaust Manifold
well check it out, my buddy has a 2.2 cavalier turbo. he recently bought a manifold for the 2.2 sabb's. well he said it will fit the cobalt 2.2 since it is the same. except all you have to do is drill a hole where one of the bolts will line up correctly. well if anybody knows or has tried it let me know cause it sounds interesting but need to know if it will work.....
Old Aug 12, 2007 | 09:35 PM
HViper's Avatar
Why??? If you want a better manifold simply get a used SS/SC manifold or even the GMPP extruded one which will bolt right up. Both are way better than a stock 2.2 manifold.
Old Aug 12, 2007 | 09:38 PM
cblt12's Avatar
im guessing for a turbo but its useless w/o tuning.
Old Aug 12, 2007 | 09:40 PM
halfj99's Avatar
i would just get the ss/sc manifold, if for no other reason ..its simpler
plus removing more meterial by drilling out the holes leaves it more vulnerable to cracking
Old Aug 12, 2007 | 09:54 PM
Halfcent's Avatar
I'm old school
I am confused too. Is it a turbo manifold that you are trying to use on your car? It would be pretty much useless to you if so.
Old Aug 13, 2007 | 12:05 AM
IonNinja's Avatar
sounds like you are talking about a saab intake manifold if you are referring to a Cavalier, a turbo and the fact that you have to tap a hole to install.
will do nothing for you if you are staying N/A
Old Aug 13, 2007 | 11:45 AM
ddrfreak's Avatar
well my buddy said its for the turbo saab but just because its turbo doesnt mean it wont work. i will just probably go with the ss/sc manifold cause its true about drilling the hole. dont want to spend money on something thats just gonna f_up l8r down the road.
Old Aug 13, 2007 | 11:49 AM
blktrax's Avatar
It won't work, you have to drill a hole to get it to attach, but you can't connect it to your downpipe, to the rest of the exhaust system. Its a Turbo flange, not a DP flange. And even if you did all the fab work to do that, you'd be cheaper and better off to get the SS/SC or a whole header DP combo.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
