exhaust manifold studs/bolts
can anyone tell me were i can find a set of exhaust manifold bolts or studs and nuts? installed my header and cannot get the studs to stay tight and it keeps leaking pretty bad, most of the nuts came off the studs and there in pretty rusted shape, would like to replace
my problem can partially and most likely be from the gasket i used, i used the one that came with header, its a thin metal with paper on each side and i should have known better, but just cause i do not want to remove it a third time i will try the copper
Best move is to order new ones from the dealer, they come with loc-tite on them and the correct locking nuts. If you wanna find the hardware locally, i'd recommend stainless steel and plenty of anti-sieze. Thread is M8x1.25
turns out header flange is bent, didnt catch it untill i just took it off to replace gasket, any ides? my down pipe is the obx 2 bolt and cant find another header than is two bolt. putting stock back on is not option
Or, you can get old-school, and do it yourself. Find a nice flat piece of concrete (most driveways work well, or sidewalks
well turns out im just blind or cross eyed, had it checked by a real mechanic (as im far from) and it isnt, just the papaer gasket that came with it blew out. but sense its off again im going to order a mid/long tube i think
if anyone is interested, im now running a pacesetter mid/long tube header (not sure which it would be called, and a 2.25 catless dp and 2.25 tsudo exhaust and i am pleased with the sound, i did not notice and low end power loss in fact it feels to pull harder low and top end both. for how cheap it was im very pleased with the set up and would recomend it to anyone looking for a good tone that is not that loud
