F35 swap
Old Jan 18, 2012 | 08:06 PM
06_ion2's Avatar
Originally Posted by Leafydialupking
Stop wheel hopping. Or see if you can swap to cavy axles, as ours seem to be strong as ****.
Got some made from Drive shaft shop for $250
Old Jan 18, 2012 | 09:04 PM
BLKLS's Avatar
I beat my car like it burned my dinner, it's got almost 93k on it, original clutch and has no problems.
Why do so many cobalt owners say they have crap trans, not just the na cars but all of them, are there just that many people that do really dumb stuff to them?
Old Jan 18, 2012 | 09:11 PM
06_ion2's Avatar
slamming gears and wheel hop is the main reason they fail.
Id say its driver error.
Old Jan 19, 2012 | 11:16 AM
newt's Avatar
There are F23's that are behind +500-600whp ecotecs and 2.4 Twin Cams that have no issues.
Hell a guy on J-Body.org blew his F23 Quaife LSD before anything else in the trans let go, swapped it out for a welded factory diff and its still in action. He runs in the 10's btw.
If your blowing the trans its from misuse, sorry to say, but many people have no issues with the F23 with MUCH more power than your making.
Hell my F23 has over 300 drag strip lauches on it, all of those on slicks, most of those being in the 1.7-1.8 60' range.
Never grinds, misses a gear or gives me trouble.
Its a much better trans than the SAAB F35 IMO.
Old Feb 3, 2012 | 09:40 AM
SlowShifter's Avatar
x30... 134k miles of abuse here and my trans is the only thing that hasn't given me an issue. F23 here...
Old Jul 9, 2018 | 11:40 PM
hexadecimal's Avatar
All this bs and no one answered the op original question
Old Jul 10, 2018 | 06:08 AM
63 Nova SS's Avatar
He asked the question 6 years ago and I doubt he still has the car. It was answered- it's not a direct fit, read through the comments. And settle down.
Old Jul 10, 2018 | 08:55 AM
Who cares if he still has the car? I did a search looking to see if the shifter is interchangeable between the SS F35 trans and the base F23 trans. Read thru all the posts and still dont have an answer. Do you know?
Old Jul 10, 2018 | 09:26 AM
They're not.
Old Jul 10, 2018 | 10:00 AM
Also I should point out the thread is about swapping an F35 into an F23 transmission, not if the shifter works or not. Take a chill pill man.
Old Jul 10, 2018 | 10:06 AM
  #36
royce777's Avatar
why don't you just buy some parts and try it out if you cant find the answer?
Old Jul 10, 2018 | 10:38 AM
  #37
Really?
Originally Posted by Blk08coupe
I've been digging all over trying to find info on this. I found that the SS halfshafts will fit in the LS hubs, the front and rear trans mounts have to be swapped, the 2.2L clutch has the same spline count as the 2.0L. What I'm trying to figure out is if the LS shifter cables/shifter assembly will work on the F35?I know I will have to get my ecu re-programmed for the different gear ratios. I'm just sick of the weak ass F23 trans. It is without a doubt the worst POS manual trans I've ever had the displeasure of using. The F35 is a much better unit and if I can swap it into my car fairly easily, then I will keep the little turd and build it for boost. If not, then off to the chopping block it goes.
Old Jul 10, 2018 | 10:41 AM
  #38
Yeah, thats what it looks like I need to do. Ill try to get some pics when I do. Then maybe this thread will have some actual useful information.
Old Jul 10, 2018 | 10:46 AM
  #39
Really?
Again chill the **** down. The thread is F35 swap and the OP is talking about swapping the entire transmission with the added shifter question. Read right over that part.
Old Jul 10, 2018 | 10:47 AM
  #40
Start your own thread that will help more than adding onto an old thread.
ben_gary
Oct 2, 2012 02:59 PM
pantywetter
Nov 10, 2011 09:42 AM
08CPE?SS
Aug 20, 2009 09:27 PM
spaz
Jun 23, 2008 11:56 PM
ssritz
Oct 3, 2006 01:24 PM
