F35 swap
F35 swap
I've been digging all over trying to find info on this. I found that the SS halfshafts will fit in the LS hubs, the front and rear trans mounts have to be swapped, the 2.2L clutch has the same spline count as the 2.0L. What I'm trying to figure out is if the LS shifter cables/shifter assembly will work on the F35. I know I will have to get my ecu re-programmed for the different gear ratios. I'm just sick of the weak ass F23 trans. It is without a doubt the worst POS manual trans I've ever had the displeasure of using. The F35 is a much better unit and if I can swap it into my car fairly easily, then I will keep the little turd and build it for boost. If not, then off to the chopping block it goes.
Why won't it ''bolt up''? Aren't the 2.0, 2.2, 2.4 all GenII blocks from 2008 up? I can't see the engines being that different. And no, the F23 isn't a ''decent'' trans by any stretch. I've put more real abuse through a 4cyl T-5 than this F23 will ever see and it lived. I'm now on my 4th one. And this one sounds like it has no trans fluid in it.
Search around. Several other people have looked into this, but I think everyone's been deterred by cost.
I know the main point of contention has always been the clutch. I know at one point someone was going to contact I believe it was Exedy about having an F35 clutch made but redrilled to mate with the 2.2, but nothing ever came of it.
Bottom line it isn't a direct swap, fab work is involved for sure.
I personally think that purely based on Torque ratings, the best GM FWD transmissions are (in order)
the torque ratings are taken from memory... and mine isn't always perfect.
If you go over on J-body dot org, you will see that they knock the F35, like nothing else;
You can do some things to improve the F23's ability to take a good beating...
I like the F35 ~ but question some of it's quoibles ~ I also think that driven resonsibly, the F23 should be able to take any abuse you throw at it...
if you want a real turd, look at the Isuzu unit used on all 1995-2000 J-bodies...
- F35 (320tq)
- Getrag282 (200tq)
- F23 (160tq)
the getrag282 is the one that has been used behind many a FWD-V8 & Fiero-V8 swap...
Yout need to run a custom flywheel that has the friction area of the LSJ but the bolt pattern of the l61, you need to run an LSJ clutch (which we all know suck for the most part, unlike L61 clutches), you will need the trnas spacer like the lsj, and you need the chassis side trans mount pockets welded into the frame. All in order to get a weaker trans with worse clutch options.
Instead put an LSD and RP or Redline atf in the f23 with a stock pressure plate + the act 6 puck clutch disk (you can find it listed under 2.2 cobalt on summit), and be golden to about 400 wheel. If you need to go up to 600, you have to drop the coil on a good bully clutch.
Its funny that I see quite a few F23 guys that want to switch to the "better" F35...
...and then there are the high horsepower F35 guys that want to switch to the F23. A couple have, actually.
I can drive standard quite well. I've been driving stick for longer than most people on this forum have been driving. I can assure you it's not me. I have a lemon of a car, pure and simple. I'm wondering if the cables, shifter or brackets aren't working properly causing all of this headache. All I know is less than 500 miles driving it fairly easy and it's back @ the stealership for the 5th time. God I hope they get it fixed soon so I can get rid of it. Let it be someone elses problem.
My F23 has been put through hell and is still in one piece with no grinds
