F35 swap
Old Jan 8, 2012 | 09:51 PM
Blk08coupe's Avatar
F35 swap
I've been digging all over trying to find info on this. I found that the SS halfshafts will fit in the LS hubs, the front and rear trans mounts have to be swapped, the 2.2L clutch has the same spline count as the 2.0L. What I'm trying to figure out is if the LS shifter cables/shifter assembly will work on the F35. I know I will have to get my ecu re-programmed for the different gear ratios. I'm just sick of the weak ass F23 trans. It is without a doubt the worst POS manual trans I've ever had the displeasure of using. The F35 is a much better unit and if I can swap it into my car fairly easily, then I will keep the little turd and build it for boost. If not, then off to the chopping block it goes.
Old Jan 8, 2012 | 09:53 PM
alleycat58's Avatar
Clutch isn't a direct bolt in IIRC.
Old Jan 8, 2012 | 09:55 PM
BankerBalt's Avatar
if anything, just get different gears. the f35 does NOT bolt onto the 2.2/2.4
DiabeticKripple's Avatar
the f23 is a decent trans btw.
Old Jan 8, 2012 | 11:14 PM
Blk08coupe's Avatar
Why won't it ''bolt up''? Aren't the 2.0, 2.2, 2.4 all GenII blocks from 2008 up? I can't see the engines being that different. And no, the F23 isn't a ''decent'' trans by any stretch. I've put more real abuse through a 4cyl T-5 than this F23 will ever see and it lived. I'm now on my 4th one. And this one sounds like it has no trans fluid in it.
Old Jan 8, 2012 | 11:22 PM
06_ion2's Avatar
you just seem too damn hard on it. dont floor it in first.
Old Jan 8, 2012 | 11:26 PM
nhanson's Avatar
F23 is actually good. Driver mod needed?
Old Jan 8, 2012 | 11:29 PM
yup
Old Jan 8, 2012 | 11:30 PM
alleycat58's Avatar
Search around. Several other people have looked into this, but I think everyone's been deterred by cost.
I know the main point of contention has always been the clutch. I know at one point someone was going to contact I believe it was Exedy about having an F35 clutch made but redrilled to mate with the 2.2, but nothing ever came of it.
Bottom line it isn't a direct swap, fab work is involved for sure.
Old Jan 8, 2012 | 11:31 PM
alleycat58's Avatar
I had always heard so, I was confused by the gung ho-ness as well.
Old Jan 8, 2012 | 11:38 PM
soundjunky's Avatar
I personally think that purely based on Torque ratings, the best GM FWD transmissions are (in order)
  1. F35 (320tq)
  2. Getrag282 (200tq)
  3. F23 (160tq)
the torque ratings are taken from memory... and mine isn't always perfect.
If you go over on J-body dot org, you will see that they knock the F35, like nothing else;
You can do some things to improve the F23's ability to take a good beating...
I like the F35 ~ but question some of it's quoibles ~ I also think that driven resonsibly, the F23 should be able to take any abuse you throw at it...
if you want a real turd, look at the Isuzu unit used on all 1995-2000 J-bodies...
Old Jan 9, 2012 | 01:10 AM
BankerBalt's Avatar
my f23 is looking at 198 wtq right now.. it's solid... the only thing i hate about it is the 1st to 2nd gear pulls...
Old Jan 9, 2012 | 01:13 AM
soundjunky's Avatar
you know that there's a difference between torque ratings, and what they can live behind right?
the getrag282 is the one that has been used behind many a FWD-V8 & Fiero-V8 swap...
Old Jan 9, 2012 | 01:17 AM
BankerBalt's Avatar
i know it can handle more, but if the OP is saying they're ****, it's not completely correct.
Old Jan 9, 2012 | 05:34 AM
Leafydialupking's Avatar
Yout need to run a custom flywheel that has the friction area of the LSJ but the bolt pattern of the l61, you need to run an LSJ clutch (which we all know suck for the most part, unlike L61 clutches), you will need the trnas spacer like the lsj, and you need the chassis side trans mount pockets welded into the frame. All in order to get a weaker trans with worse clutch options.
Instead put an LSD and RP or Redline atf in the f23 with a stock pressure plate + the act 6 puck clutch disk (you can find it listed under 2.2 cobalt on summit), and be golden to about 400 wheel. If you need to go up to 600, you have to drop the coil on a good bully clutch.
Old Jan 9, 2012 | 06:10 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Its funny that I see quite a few F23 guys that want to switch to the "better" F35...
...and then there are the high horsepower F35 guys that want to switch to the F23. A couple have, actually.
Old Jan 9, 2012 | 11:47 AM
soundjunky's Avatar
Originally Posted by Leafydialupking
... All in order to get a weaker trans with worse clutch options. ...
spoken like someone from dot org... oh wait a minute
Old Jan 10, 2012 | 05:45 PM
07cobaltguy's Avatar
The op must not really know how to drive. My car has mulitple track runs at over 300wtq and no issues what so ever on the trans end.
Old Jan 10, 2012 | 05:54 PM
1LowLS's Avatar
the F35 trans input shaft is larger then the F23.Stick with the F23.It's made by Getrag,My F23 has been put through hell and is still in one piece with no grinds
Old Jan 10, 2012 | 06:08 PM
nhanson's Avatar
i wish i was 5 speed
Old Jan 11, 2012 | 11:59 AM
IonNinja's Avatar
Just be glad you don't have the Aisin trans that came in the 03-04 Ions lol
Old Jan 16, 2012 | 10:34 AM
Blk08coupe's Avatar
I can drive standard quite well. I've been driving stick for longer than most people on this forum have been driving. I can assure you it's not me. I have a lemon of a car, pure and simple. I'm wondering if the cables, shifter or brackets aren't working properly causing all of this headache. All I know is less than 500 miles driving it fairly easy and it's back @ the stealership for the 5th time. God I hope they get it fixed soon so I can get rid of it. Let it be someone elses problem.
Old Jan 17, 2012 | 07:53 AM
mmcgee123's Avatar
My f23 has had over 300 wtrq for 40-50k now I just keep breaking axles I wanna swap lnf axles hubs and spindles I just don't know if the splines are the same
Old Jan 17, 2012 | 10:12 AM
Stop wheel hopping. Or see if you can swap to cavy axles, as ours seem to be strong as ****.
Old Jan 18, 2012 | 08:05 PM
Laf729's Avatar
zzp have the lsj flywheel with bolt patern for 2.2/2.4 crank
