Fast 2.4 IM Help Please
Old Apr 8, 2010 | 02:35 PM
flyy's Avatar
We took the 2.2 IM off and i had a whole new set of gaskets except for the crank thing gasket in the very center so we tried to rig it with the old one, then we hooked everything back up the way we took it off and now it doesn't run right it starts up fine then revs up to 3.5 rpms then settles and loafs like it has cams. not sure what we did wrong we followed a how-to guide but now we're stuck any help?
Old Apr 8, 2010 | 02:48 PM
Take2-08LT's Avatar
For one you can't rig the crankcase seal in from the 2.2 and have it seal right. Also mine came with an adapter plate for the 2.2 throttle body and it did the same kind of thing. I took it off and bolted the TB right bto the IM and it worked perfectly. And hopefully you cleaned all mating surfaces prior to install. If not you will most likely have a vacuum leak witch will cause high/rough idle.
Old Apr 8, 2010 | 05:31 PM
Spanky's Monkey's Avatar
i do believe 07 and up don't need that plate. i could be wrong.......
Old Apr 8, 2010 | 05:43 PM
warrenb213's Avatar
07+ do not require the adapter.
the "gasket" or seal that your referring to is absolutely necessary for proper operation.
get the seal, reinstall.
Old Apr 8, 2010 | 07:00 PM
flyy's Avatar
where do i get the seal from and what do you mean "clean all the matting surfaces" i do not understand what matting surfaces are.
Old Apr 8, 2010 | 07:24 PM
warrenb213's Avatar
specifically the surfaces where the head and intake mani join.
Old Apr 8, 2010 | 08:02 PM
reaper89's Avatar
isnt the center crankcase vent supposed to be completely sealed on the 2.4? when i got my 2.4 mani i got a small metal seal that covered the hole.
*edit* heres the part number for the seal vent #12589516 on gmpartsdirect.com
Old Apr 8, 2010 | 09:56 PM
flyy's Avatar
thank you sir just ordered it, my car was running like **** without that seal and i got it from zzp i was sure that they would've sent me all the appropriate gaskets but i guess not. but i got it coming now just another 2 weeks to wait since i live in egland lol the funny part is the shipping and handling is more than the actual gasket.
Old Apr 8, 2010 | 10:27 PM
huckernage's Avatar
what is your exhaust setup.
Old Apr 8, 2010 | 10:28 PM
reaper89's Avatar
your welcome. Enjoy the new found power band the 2.4 gives
Old Apr 8, 2010 | 10:31 PM
flyy's Avatar
custom 2.5 right now but i already ordered the vibrant cat-back and i have the vibrant hdr/dp catless
Thank you I'm looking forward to it. the car is already twice as fast as before and that's just with the trifecta tune haha.
Old Apr 8, 2010 | 10:43 PM
huckernage's Avatar
ohhhhhhh
your vibrant is not install yet
Old Apr 8, 2010 | 10:47 PM
flyy's Avatar
ohhhhhhh
nah not yet it's in the mail. got it from thmotorsports
Old Apr 9, 2010 | 10:18 AM
hugemurph4's Avatar
brake booster hose isnt recconected maybe or it popped off somewhere
Old Apr 9, 2010 | 02:45 PM
flyy's Avatar
Originally Posted by hugemurph4
brake booster hose isn't reconnected maybe or it popped off somewhere
No it was connected I just didn't have the metal gasket for the crank seal or what ever so i ordered it last night ill get it soon. We ended up putting the 2.2l IM back on because of that so that sucked not to mention my buddies neighbors were pissed off because my car is completely straight pipe with a 100$ fart can on the end of it.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
