finshed 2.2 super charged @ 10 psi
#201
Like I said, get a Interceptor gauge so you can see what % you're running them at and if they are pass 80% (which I'm absolutely sure they are if they are going that ungodly rich) you have a major issue at hand because you can lead them to go static and have more injector mechanical issues.
#202
Yeah...it's rich as **** you're not realizing atleast from the point of view of injector duty cycle of what 34 # injectors running at.
and just to be clear we are using the stage 2 injectors.
#205
well i'll skip reading thro all the bull ****....
I'll give you credit for doing the swap...
but hot dam i hope to god YOU dident do it and that somebody else did, you totally miss-named a few IMPORTANT sensors...such as your suposed AIT1(its a SCIP sensor your AIT1 is in the maf) sensor and such....but hey i'll let that slide since your HUGEST **** up is that fact that you some how think your ECM is reading that 2bar MAP sensor...
WOW i haven't seen such wrong information posted like EVER....your ECM in UNABLE to read anything above 14.7PSI(atmospheric pressure, at sea level that is) your car IS in OPEN loop, thats why your AFR's a are random, and mostly unrepeatable....your getting by on pure luck...
if you don't get a SAFC or your SMT unit in there like NOW your ***** gonna blow....its only a matter of time.
i hope you continue to develop this project, you are FAR from done.
#206
If the injectors are exceeding duty cycle, this could result in actual injector failure. So last thing he would want to do is run at full throttle and then the injector fails in one shape or form.
Also, exceeding a high duty cycle will effect how well they spray at the valves.
Another thing, if you don't take control of your fuel injectors soon, you will lead to misfires because the combustion chamber is so wet that the tip of the spark plugs won't be capable of creating a spark strong enough to ignite the fuel.
9s and 8s are INCREDIBLEY rich fuel mixtures. I'm suprised you're even able to reach the 8s. You're actually LOSING power in those mixtures.
Running that large of fuel injectors and trying to control with a piggyback unit (remember, it changes voltage from STOCK settings) you're going to run into more issues. 42 # (I believe that's the stage 2 size injectors) is MUCH larger than your stock 24 # injectors. You're only going to be able to adjust or take away so much fuel during low engine speeds.
Just food for thought.
#207
I'm old school
Not to mention that once you go static, you can't deliver any more fuel. So you get lean with any further increase of demanded power.
A recommended maximum duty cycle for a given application is 80%.
#208
WHOA i dident see that part.....8's and 9's for AFR's....
can you say RICH KNOCK!!! thats ****** crazy...your gonna burn thro plugs with that much fuel....
why do people who have such a small grasp on things do these projects?
good luck man.....you'r gonna need it at the rate we've seen things going
#217
So I've been reading about the SMT-7, and it seams like he would be able to control everything with it. I get that you are tricking the ECU, but compared to the HPT, if and when it comes out, what are some of the advantages/disadvantages between the two?
#218
Not really advantages over per say...but HP Tuners gives you MORE control.
#220
we have a 3 bar map its not hooked up right now, i can agree with you, but being a DSMer (and that mean Diamond Star Motors AKA: 4g63t) which is NOT mitsubishi, ive run more boost than anyone on these forums. and for the crank walk bullshit, you have no idea what your talking about 6bolt motors dont walk.
as soon as we have a little more time put into this we will be tuning with SMT7
yellowshobalt IS NOT using the 5th injector
Ding ding ding NOT TRUE!!! I know of someone actually our mechanic at the shop and he has 2 dsm and HIS 6 BOLT CRANK WALKED!! I have seen it in person it walked and sheared one end of the crank razor sharp!
#222
I think that you are refering to yellowshowbalt with that comment. He was not the one speaking though. It was his friend logged on under his screenname. Not that it matters, it's no excuse to criticise his speech or appearance. In this thread your age is very apparent.
To all the others who posted "helpful" comments, shame on you. This guy just accomplished something that a bunch of you have been talking about doing for a long long time. You call him a liar.........he gives you proof (on his lunchbreak none the less!!!). Then you offer up your "helpful" comments. Could you be any more negative? Is it your car or motor in the video? No it's not. So layoff of him. If you have some useful advice then perhaps you should learn to state it in a useful way. shortbus.net FTL on this thread.
Yellowshowbalt (or his friend), maybe you should take this project over to the redlineforums where people are (for the most part) much more mature, informative, and above all.........courteous.
Great job on this project so far. Now you just gotta shore up the holes and you'll have one bad little balt
If my age is being "shown", im assuming you think im about 16, so with that said....you should be hit with a shovel.
Thanks.
#223
I have seen the timing charts for HP tuners, and they are huge, and although I haven't seen if SMT7 has timing charts, I would assume that HPT is just more values that can be adjusted. Does that sound about right?
Now I am also planning on supercharging my 2.2 in probably 4-6 months. Hopefully HPT will have tuning for the e37 by then, but if it doesn't, would it be safe to use the SMT-7?
I'll probably be bugging Blown4banger and Cobalt Supercharged to make sure I do everything right. (Just some forewarning guys )
#224
while this is true, and possible on ANY engine...the 7bolts were known for that issue.
#225
Okay, cause I was watching the guys tuning La Banana last weekend at the pavilions. They had done a bunch of data logging, and then started changing and smoothing out graphs.
With HP Tuners, you're leaving your computer in control and you're just changing everything through the computer. Flaw with piggybacks is that you're adjusting from stock settings and are only given so much adjustments without the computer counteracting. Good thing is that your computer still has it's emergency counter-measures still intact even with a piggyback setup.
