First Custom Road tune on the E16!
Old Mar 18, 2008 | 10:22 PM
  #226
NWAE Cobalt's Avatar
yes, updates will have to be paid for, although he is willing to discount them. exact date is not out yet although we are dyno tuning it saturday and track on sunday The auto 2.2 tune will be worked on this weekend as well.
Old Mar 19, 2008 | 03:22 AM
  #227
cobalt_driver's Avatar
kinda iffy on the situation, but its better than nothing. i'll make my decision based on ur numbers. i'm very interested in the timing, sai delete, running 93, etc...
sry for asking so many ?'s but, what will come with the base tune? and what type of tunning will need to be purchased separately?
base tune is set at 300 bucks correct? has clear given prices on the upgrade tunes?
Old Mar 19, 2008 | 10:35 AM
  #228
i beleive they are saying 250$ right now. The base tune will be a tune for whatever mods you declare when you start the tune..then small updates (tire size change, rev limiter change, etc) will be a discounted rate (dont have the figure) all other major retunes (new injectors, new cams...etc) will have to pay a discounted rate...but basically a new tune. But for anything but cams or F/I...you can do a few mods and then get one tune...cheaper that way
Old Mar 19, 2008 | 10:52 AM
  #229
copson20's Avatar
so when the tune comes out, you send them your VIN and what every mods you have done like manifold swap and what not for $250. then later on when you get more up grades and need a tune you pay them for a discounted rate
Old Mar 19, 2008 | 11:27 AM
  #230
IonNinja's Avatar
i don't understand why you guys are worried about future mods anyway
tuning in the last thing you should be doing, it shouldn't be mixed in with the rest of your mods.
Old Mar 19, 2008 | 02:52 PM
  #231
bridfi's Avatar
x2
Old Mar 19, 2008 | 03:58 PM
  #232
right...but like i am tuned for all the mods i have now, but if i were to upgrade the cams, it would need to be redone....
Old Mar 19, 2008 | 05:38 PM
  #233
IonNinja's Avatar
thats why you wait until after you get cams and then get the tune
but its okay since you're testing...
Old Mar 19, 2008 | 05:44 PM
  #234
umrdyldo's Avatar
Well i think you should get a tune if fully bolted. If you add cams or turbo later you should have a different tune made to cover it. So i can at least understand two or at most three tunes over the life of the car
Old Mar 20, 2008 | 10:44 AM
  #235
thats about what ill have. im going to tune now, when i do the 2.4 intake and a few other small items, and then when/ if i go FI
Old Mar 23, 2008 | 01:26 PM
  #236
so we dyno tuned the balt yest turned out very good. ended up that we started out before the tune at 136whp (corrected SAE #s) and with the tune i am at 147whp(corrected sae #s). I have the dyno sheets but they are not up yet and you can all compare them. The car runs GREAT and we found that 5th gear on this car at 6500 rpm will run you to 162mph we have a dyno showing this as well...so no spectics!! He said that he should be ready to market the tune for the 2006 2.2 manual (auto tuning to come soon) within about a mo...will let you know exactly when he is ready when i hear. He is VERY excited to get set on this!!!! He is actually looking to buy a 2006 2.2l cobalt
any questions?? (except for dyno sheets, they will be up later)
Old Mar 23, 2008 | 02:36 PM
  #237
brandon2.2's Avatar
awsome! did you guys adjust or try to remove the rev limiter? can you? and can you tune for F/I and NO2? this will sort of be a mail order tune right? I am so excited....I just cant hide it....
Old Mar 23, 2008 | 02:43 PM
  #238
mrsilent13's Avatar
any new news on the 05 2.2 auto......
Old Mar 23, 2008 | 03:14 PM
  #239
mail order yes and no lol, he will email back and forth tunes. as for the rev limiter...not yet. f/i yes, though that takes more work lol. he is going to test my gf 2.2l auto soon, he said that should be a breeze now that he is done with this
Old Mar 23, 2008 | 04:28 PM
  #240
mrsilent13's Avatar
f/i ftmfw!!!!!
Old Mar 24, 2008 | 12:03 AM
  #241
he has been working on 2.4redss' tune for the garett kit on the 2.4...the stock tune they give you with the fuel booster works like CRAP!!! they have been getting it running VERY well!! keep an eye out for a thread on that
Old Mar 24, 2008 | 10:11 PM
  #242
Kwin's Avatar
SICK!!! bring on the auto!!!
Old Mar 24, 2008 | 11:14 PM
  #243
dyno: first line is last untuned dyno run, then the second is yest last tuned dyno run
speed...look at bottom for mph...the loopish is cause i was going to lift when the speedo topped out...then i decided to take her to redline
Old Mar 24, 2008 | 11:17 PM
  #244
M-Dub's Avatar
And the point of going above 5500 is what? You loose power at that point....
11 hp and 3.5 ft. lbs... huh? Well okies!
Old Mar 24, 2008 | 11:19 PM
  #245
what about it???
Old Mar 25, 2008 | 01:44 AM
  #246
tonio5555's Avatar
Dyno chart is much like what I expected, same power curve and all just slightly higher numbers. 10hp increase with bolt ons isn't bad at all on a 4 cylinder.
Old Mar 25, 2008 | 02:55 AM
  #247
im not worried about tuning now. what i have been concerned about is what comes along with the BASE tune. also, i have been rocking the boat on whether i want cams or not. since there is alot u can't tune to compensate for the cams i am interested. ion u were in the thread a while ago about tuning for cams with switt n a couple other members. this tuning device should compenstae for the cams. also, for those of us with the SAI need to get it removed which this device will remove. also, when i run cams i'll run the 32lbs injectors, header back, 2.4 manifold, and probably a ported n polished head. 32 lbs should be plenty for those mods.
i'm thinking in advance of what i can n cannot do (mod wise) and this opens up some options.
Old Mar 25, 2008 | 02:57 AM
  #248
M-Dub's Avatar
what about it???
Nuthin'.... you would get a lot more if it was truely CUSTOM! But what do I know!
Old Mar 25, 2008 | 07:44 PM
  #249
Sw4y1313's Avatar
Dont waste your money on 32 lb injectors. Even with Stage 1 cams you shouldnt over run the stock injectors.
Old Mar 25, 2008 | 08:32 PM
  #250
Jn2's Avatar
Jn2
or just get urself soem lsj injectors, they are bigger than stock, and guys here sell them for a average of 50 bucks...i will interested in this tune when its out, now if they email it, tell me, how am i going to get that tune, on my ecm??? have a laptop, but after that what?
