Gm Ecotec Supercharger Kit Part #'s
Does a list exist of all the parts for the supercharger kit for the cavalier exist?
I know where I can get the kit
http://paceperformance.com/index.asp...&ProdID=167186
But there isnt a list of what the kit contains
I wanna see if its possible to piece this together by myself.
Yes GM build book has parts list. Sorry don't have link. No you can't do it yourself. many of the adapters have been found to only exist in that Kit. Now I'm not sure if you could find things like the TB adapter from a Cavy guy. Most of the parts can be had if you search the internet hard enough.
SUPERCHARGER PARTS LIST
PARTS LIST
Part Description Part Number
Supercharger Kit 1780003
Clamp - Fuel Pressure Regulator Hose-Intake Manifold End 10028454
Hose, Brake Booster 10358940
Nut - U-Nut Oil Level Indicator Tube Support 11507067
Nut - U-Nut Radiator Hose Support 11507067
Clamp - Coolant Hose Cap 11516226
Bolt/Screw - Intake Manifold Bracket-to-Engine Block 11516342
Bolt/Screw - Intake Manifold Bracket-to-Intake Manifold 11516506
Nut - Intake Manifold 11516076
Bolt/Screw - Radiator Hose Support 11516757
Bolt/Screw - Drive Belt Idler Pulley Bracket 11518048
Bolt/Screw - Generator Relocation Bracket 11518051
Bolt/Screw - Intake Manifold 11518062
Nut - Intake Manifold-to-Head 11518532
Bolt/Screw - Generator Relocation Bracket 11589134
Bolt/Screw - Drive Belt Tensioner 11589147
Bolt/Screw - S/C TO Intake Manifold 11589214
Bolt/Screw - Oil Level Indicator Tube 11589299
Bolt/Screw - Drive Belt Tensioner 11589312
Pin, Connector Female 12048074
Connector Pin Seals 12048087
Lock-Connector - IAC Connector 12052634
IAT Connector Replacement 12052641
Map Connector Replacement 12110293
Zip Tie 12355066
Connector - PCV Tube 12581198
Tensioner Assembly - Drive Belt 12583180
Supercharger Assembly 12584331
Vacuum Hose - Fuel Pressure Regulator 12584337
Gasket - Supercharger Outlet 12584342
Manifold Assembly Intake 12584348
Gasket - Intake Manifold 12584359
Bracket Assembly - Drive Belt Idler Pulley 12584364
Bracket - Generator Relocation 12584365
Tube Assembly - Intake Manifold-to-Fuel Regulator (LSJ Purge Valve Hose) 12584369
Brace - Intake Manifold 12586632
n GM SPORT COMPACT Performance Build Book 39
PARTS LIST
Adapter - Throttle Body 12590814
Belt - Accessory Drive 12590815
Wire Assembly - Map Sensor 12590818
Data File PCM Engine Calibration 12590819
Data File - PCM Engine Calibration 12590820
Stud - Intake Manifold 12590821
Stud - Intake Manifold 12590822
Bolt/Screw - Throttle Body Adapter (M6 X 20 mm Socket Head Cap Screw) 12593676
Washer - 17 mm OD For a M8 Bolt x 4 mm Thick 12593677
Sticker, Carb E/O 12593900
Template - Intake Manifold Gasket Cut Out 12593902
Instruction Cd 12593903
Injector Assembly Fuel 12593904
Plug, Map Sensor 12593906
Gasket - Throttle Body Adapter Plate (O-Ring) 12593905
Template - Dip Stick Tube Support Bracket 12593907
Support - Radiator Hose 12594613
Cap Assembly - Cool Hose 15544596
Cable Assembly - Cruise Control 22688111
Hose Assembly - Radiator Inlet 22718761
Vacuum Fitting - Waste Gate 24507839
Air Duct 24575436
Premium Fuel Decal 25602518
PARTS LIST
Zip Tie 12355066
PARTS LIST
Air Duct 24575436
Yeah, I might just end up buying the kit from someone when the time comes. haha, it would take forever to find all that stuff. Unless I found a totaled ss that got hit in the rear.
That same list is on Jbody.org and they are having troubles finding half that stuff. Im sure it would cost the same if you bought all those parts from GM.
