Gmpp Cai
Gmpp Cai
has anybody modded they're GMPP to be CAI??? well i have thought of buying the spectre pieces to make a whole CAI, but than i though, the spectre pieces heat up 2 quick, they get to hot, my gmpp is more heat resistant...so i did it...i took a 90 degree elbow, a 60 degree elbow, and a straight 6" to do it...
yep....
you got a point about the CAI, unfortunately, Spectre does overcharge you if you buy one of theirs pre-built. However, if you can build it for yourself, I ran the numbers with a mockup kit and it would cost you about $150 of separate parts(tubes, connectors, filters, bends) which is a far cry from the $230 from the Injen, but considering you don't know how far back to place your MAF and the possibility of misjudging something, theres the risk you could run more than $150. Just FYI
how was the outcome? I'm just looking at the RKSPORT hood that works directly with the GMPP CAI, anyways..for now i have a COLD AIR intake that i made out of a tube for 10 dollars haha, it works damn good
where do you have your sensor going, im thinking about making a temporary one until i get mine.
what CEL did you throw? maybe there was just a leak somewhere? When i installed my GMPP got a CEL cuz part of the rubber tubing pulled away from the metal piping and i was getting a lean code.
BTW, do you happen to know the size of the neck on the filter? I am looking to rplace mine with an AEM and not sure what size it is. I know its a 5" element but I need the neck diameter
