Gmpp Exhaust
Old Jul 22, 2007 | 09:57 PM
JKennedy1612's Avatar
Originally Posted by razorhead89
seems to be some mixed answers....sorry for the noobness.....the stock manifold already has a downpipe??
Go outside and look at your car. Do you know the function of a manifold/header? It's the exhaust that's released from your pistons after the combustion stage in the cylinder. There's 4 because we have 4 cylinder cars. In a Vette for example, there's two manifolds on both sides of the engine block because there's 8 being a V8. People get after market manifolds (which are called headers) that are larger in diameter which allow more air to flow through.
The manifold releases the exhaust(by product of the explosion from your cylinder) through pipes out through your exhaust tip. The other parts, like a DP are ways of breaking down the exhaust system in order to replace specific parts. The DP is connected to the manifold and yes, you HAVE one already, every car does. Hopefully that clears things up a bit.
Old Jul 22, 2007 | 10:03 PM
razorhead89's Avatar
thank you
Old Jul 22, 2007 | 10:05 PM
thank you
No problem dude
Old Jul 24, 2007 | 02:50 PM
how big is the GMPP exhaust tip???...straight cut?
Old Jul 24, 2007 | 04:01 PM
denn454's Avatar
Its huge.
I bought the straight cut one with mine but didn't end up using it because its too big. It wouldn't be bad on an SS car because they have a different rear bumper, but on a base model the tip is just too big, and it hangs too low to look good.
The SS's use different bumpers, the SS/NA (2.4 non supercharged. NA is naturally aspirated, means it doesn't have a turbo or supercharger) is close to yours, except it has a plastic insert in the middle that extends over the exhaust area. it is about an inch lower than your bumper. The tip fits much better with that style of bumper. The SS/SC (SC is supercharged) has a different bumper, look around and you'll find a lot of pictures, it also hangs down a little lower.
If you already bought the tip try it and see if its your thing. if it is, eh, thats great. (be prepared for a few rice comments) if you haven't bought it, don't.
Old Jul 24, 2007 | 09:27 PM
so it will fit...but its just going to look huge....thanks for clarifying this....+rep...peace
Old Jul 24, 2007 | 10:00 PM
YSUsteven's Avatar
so a gmpp exhaust will connect to a stock header??
Its a catback exhaust, which means exactly waht it sounds like.
It replaces the exhaust from the cat converter back. It should bolt right up to the existing cat.
Old Jul 25, 2007 | 12:59 AM
justindar's Avatar
heres a real good sound of the different exhaust the sound clip is right below the picture. under the drawn out picture.
http://www.crateenginedepot.com/stor...P1379C146.aspx
Old Jul 25, 2007 | 03:52 PM
denn454's Avatar
no problem. I can get some pictures of it if you want to see how it looks. it will take me about a week to get to my parents house where i have the tip at but i can take a pic next time i'm there with it on. if you want.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
